Report Builder Physical Inventory report
That worked very well, Thanks!
Is there an 'opposite' of Previous to look at the 'Next' number? I
might be able to make it show the missing series of numbers that way.
Thanks!!
Ann
--- In vantage@yahoogroups.com, pjw@... wrote:
> Try using the PREVIOUS() command in report builder. Example
> IIF(number <> (Previous(Number) - 1),'Hey I'm missing one!','OK')
> Patrick Winter
> -----Original Message-----
Behalf Of
> amfabllc
> Sent: Wednesday, March 22, 2006 8:08 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Report Builder Physical Inventory report
> We are on Vantage 5.00.329. I have written a Report Builder
report which
> lists each inventory tag entered - filtered by the group. What I
have not
> been able to figure out is how to create a formula (or probably an
> aggregate) when a tag or series of tags are missing (not
entered). I want
> to be able to at least flag the line above or below the missing
tag #'s -
> and - hopefully even report the missing tag #s. I currently have
to export
> to Excel and use formulas to flag missing tag #s.
> What I have done so far to try to achieve this is to do a formula:
> Num(TagNum), turning the tag number into a value. I sorted and
grouped the
> report by Num(TagNum) and tried to make an aggregiate 'Variance'
that would
> realize when a number(s) was missing from the sequence. This is
where I
> need help please - I have not been able to figure this out.
> (I also do an exception report filtered to show Num(TagNum)=?,
which gives
> me tag numbers that someone entered incorrectly with a letter or
symbol in
> the entry. I will be able to make another exception report using <
the
> beginning tag# or > the ending tag# to find the remainder of bad
tag entries
> out of sequence. I'll just have to watch for any entries that the
tag
> number was entered with a preceding '0' which would make the value
different
> than the entry. These I think I have under control).
> I realize that Vantage offers some more advanced inventory options
such as
> generating tags and barcoding, however this is the way that
management wants
> out next inventory to be done.
> Thanks in advance for all help!!
> Ann Rohyans
> AMFAB
must have
Builder and
> Yahoo! Groups Links
> This e-mail and any attachments may contain confidential and
> privileged information. If you are not the intended recipient,
> please notify the sender immediately by return e-mail, delete this
> e-mail and destroy any copies. Any dissemination or use of this
> information by a person other than the intended recipient is
> unauthorized and may be illegal.
We are on Vantage 5.00.329. I have written a Report Builder report
which lists each inventory tag entered - filtered by the group. What
I have not been able to figure out is how to create a formula (or
probably an aggregate) when a tag or series of tags are missing (not
entered). I want to be able to at least flag the line above or below
the missing tag #'s - and - hopefully even report the missing tag
#s. I currently have to export to Excel and use formulas to flag
missing tag #s.
grouped the report by Num(TagNum) and tried to make an
aggregiate 'Variance' that would realize when a number(s) was missing
from the sequence. This is where I need help please - I have not been
(I also do an exception report filtered to show Num(TagNum)=?, which
gives me tag numbers that someone entered incorrectly with a letter or
symbol in the entry. I will be able to make another exception report
using < the beginning tag# or > the ending tag# to find the remainder
of bad tag entries out of sequence. I'll just have to watch for any
entries that the tag number was entered with a preceding '0' which
would make the value different than the entry. These I think I have
under control).
such as generating tags and barcoding, however this is the way that
management wants out next inventory to be done.
Ann Rohyans
AMFAB
What tables are you using?
Sent: Wednesday, March 22, 2006 9:08 AM
missing tag #s.
under control).
Ann Rohyans
AMFAB
Yahoo! Groups Links
CountTag linked to Part
> From: amfabllc [mailto:amfab@...]
report
What
(not
below
tag
> missing tag #s.
missing
been
which
letter or
report
remainder
any
have
> under control).
that
> Ann Rohyans
> AMFAB
access. )
> Yahoo! Groups Links
Patrick Winter
amfabllc
We are on Vantage 5.00.329. I have written a Report Builder report which
lists each inventory tag entered - filtered by the group. What I have not
aggregate) when a tag or series of tags are missing (not entered). I want
to be able to at least flag the line above or below the missing tag #'s -
and - hopefully even report the missing tag #s. I currently have to export
Num(TagNum), turning the tag number into a value. I sorted and grouped the
report by Num(TagNum) and tried to make an aggregiate 'Variance' that would
realize when a number(s) was missing from the sequence. This is where I
(I also do an exception report filtered to show Num(TagNum)=?, which gives
me tag numbers that someone entered incorrectly with a letter or symbol in
the entry. I will be able to make another exception report using < the
beginning tag# or > the ending tag# to find the remainder of bad tag entries
out of sequence. I'll just have to watch for any entries that the tag
number was entered with a preceding '0' which would make the value different
I realize that Vantage offers some more advanced inventory options such as
generating tags and barcoding, however this is the way that management wants
Ann Rohyans
AMFAB
Yahoo! Groups Links
