go to CUSTOM REPORT LINK under master file maintenance, Under edit select ADD browse to your report PRL file. Select the file to add. Then go to system utilities under MENU STRUCTURE MAINTENANCE. Follow the instructions there. Be sure to ad "UD" to the file ID.
I removed the custom report link from ALL area's except System Utilities so I had a measure of control over the reports. I needed this to comply with QS9000 requirements. Which we just so happened to be recomended for certification last friday. VANTAGE was key in getting our QS9000 cert.
Shirley
Shirley
