What am I missing here? I've done this on other reports with no problems but can't seem to figure this one out. Thanks.
Did you load the XML in Database Expert…is there any tables that are not linked to anything?
Sent: Tuesday, April 26, 2016 1:28 PM
Subject: [Vantage] Report Data Definition and Crystal Reports
I duplicated the SO pick list system report and wanted to add a field that already exists in the included OrderHed table(OrderHeld). I moved that field from the "Excluded Report Fields" to the "Included Report Fields" and saved it. I then opened the new report in Crystal. I can't seem to find a way to get that new field to show up. I've printed a SO pick list and exported it to xml and tried using that as a datasource and tried refreshing the table data. Here is the error I get when trying to use it as a datasource.
Logon Failed. Details: System.Data: The table (Section) cannot be the child table to itself in nested relations.
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
