Report Data Definition and SSRS Time Report - TimeWeeklyView
Hi,
I’m working to update Time Report and looking into the standard report data definition seeing TimeWeeklyView Schema Table, is it a table? Why I cannot see it using BAQ?
I’m trying to make PhaseIDDescription as calculated field. how can I do that?
This would be found in the ProjPhase (I may be off on the exact name) table under the field “Description”.
PhaseIDDescription is incorrect on the standard report, any thought?
Do you want to edit the standard report or a BAQ?
If you are editing the report, then the field you need is right there. If you are editing/creating a BAQ, then use the info I sent earlier.
got it thanks
