I’m getting an error message when trying to get into the data definition for our Job Traveler. The Job Traveler is working fine, however, I would like to modify it. Is there a way around the error so that I can fix it and/or add to it? Any suggestions is greatly appreciated.
The error is:
An error occurred while updating the entries. See the inner exception for details.
Application Error
Error Detail
Message: An error occurred while updating the entries. See the inner exception for details.
Inner Exception Message: Violation of PRIMARY KEY constraint ‘PK_RptExclude’. Cannot insert duplicate key in object ‘Ice.RptExclude’. The duplicate key value is (CigJbTrav4b, Part, ERP, Part, Number01).
The statement has been terminated.
Program: Epicor.ServiceModel.dll
Method: ShouldRethrowNonRetryableException
Client Stack Trace
at System.Data.Mapping.Update.Internal.UpdateTranslator.Update(IEntityStateManager stateManager, IEntityAdapter adapter)
at System.Data.Objects.ObjectContext.SaveChanges(SaveOptions options)
at Ice.IceDataContext.SaveChanges(SaveOptions options) in c:_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 352
at Ice.Services.BO.RptDataDefSvc.syncExcludes(String rptDefID) in C:_Releases\ICE\3.1.600.8\Source\Server\Services\BO\RptDataDef\RptDataDef.cs:line 2593
at Ice.Services.BO.RptDataDefSvc.OnBeforeGetByID(RptDataDefTableset ds, IEnumerable1 queryParameters) in C:\_Releases\ICE\3.1.600.8\Source\Server\Services\BO\RptDataDef\RptDataDef.Designer.cs:line 2000 at Ice.TablesetBound
3.InnerGetByID(IceDataContext dataContext, Int32 pageSize, Int32 absolutePage, Boolean& morePages, TFullTableset tableset, IEnumerable1 queryParameters) in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 622 at Ice.Services.BO.RptDataDefSvc.GetByID(String rptDefID) in C:\_Releases\ICE\3.1.600.8\Source\Server\Services\BO\RptDataDef\RptDataDef.Designer.cs:line 1985 at Ice.Services.BO.RptDataDefSvcFacade.GetByID(String rptDefID) in C:\_Releases\ICE\3.1.600.8\Source\Server\Services\BO\RptDataDef\RptDataDefSvcFacade.cs:line 732 at SyncInvokeGetByID(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func
2 func) in c:_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in c:_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 47
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in c:_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
Inner Trace:
: at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() at System.Data.SqlClient.SqlDataReader.get_MetaData() at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted) at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource
1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.Mapping.Update.Internal.DynamicUpdateCommand.Execute(UpdateTranslator translator, EntityConnection connection, Dictionary2 identifierValues, List
1 generatedValues)
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Ice.Proxy.BO.RptDataDefImpl.GetByID(String rptDefID)
at Ice.Adapters.RptDataDefAdapter.OnGetByID(String ID)
at Ice.Lib.Framework.EpiBaseAdapter.GetByID(String stringId)
at Erp.UI.App.RptDataDefEntry.Transaction.adapterGetByID(String id)
Inner Exception
