To Lookup an SCR, myEpicWeb, on left, link to search CRs...
However, from there it is cryptic...Sometimes you can find by the
number, but most of the time not...I am looking today and find putting
in the Module and either no keywords (to show all) or some keywords to
narrow your search...They have a different number system for the CR -
but I have found some reference the SCR within the body of the CR...
Karen
Of Brian W. Spolarich
Sent: Friday, August 07, 2009 11:31 AM
Subject: RE: [Vantage] Re: Report Data Maintenance for PackList
Thanks Michael. How does one actually look up an SCR? I got a runaround
when I asked Tech Support on this.
I'm wondering if it is fixed in .408a.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@...
<mailto:bspolarich%40advancedphotonix.com> ~ 734-864-5618 ~
www.advancedphotonix.com
Behalf Of Michael McWilliams
Sent: Friday, August 07, 2009 12:23 PM
Subject: [Vantage] Re: Report Data Maintenance for PackList
I reported this to Epicor a while bak because I had the same problem. I
ended up just adding via ODBC.
Here is the SCR. 45353 REP PackSLip Report Data
"Brian W. Spolarich " <bspolarich@...> wrote:
Karen
-bws
Picometrix
bspolarich@...
>show
> I want to bring in related data for a variant of the PackList report.
> So for example I want to bring in ProductGroup data from OrderDtl, or
> even just fields from OrderDtl. I see OrderDtl listed as a table on
> Report Data Maintenance, and I've made a copy of the RDD for PackSlip,
> and a report style that uses it. But when I generate the report from
> Customer Shipment Entry I don't see a OrderDtl table in the XML. The
> XML does get larger as I add fields, but only because those fields
> up as ReportLabels./
> Ultimately I'm trying to create a Commercial Invoice, and it seems
> like PackSlip is the place to start. But I'm not understanding why
> tables that are shown in the Report Data Definition aren't included in
> the output.
> I don't see a way to add a relationship between ShipDtl and OrderDtl
> either. When I try to do that I can't select any table that I'm
> interested in linking to.
> I also tried to add a UD table to the RDD without a relationship
> defined, which I would expect to result in the entire UD table being
> included. It doesn't show. I added ABCCode to the report, and again it
> only includes the fields in the ReportLabels, not the data itself.
> I was able to add a relationship to Part and get a couple of fields
> from Part, but if I try to add ProdGrup as a relationship to Part I
> don't get anything even though I define the links correctly (via
> Company, then ProdCode).
> I'm sorely confused about how this thing is supposed to actually work.
> Picometrix------------------------------------
> bspolarich@...
> <mailto:bspolarich@...> ~ 734-864-5618 ~
> www.advancedphotonix.com <http://www.advancedphotonix.com>
