The solution to this is to select Left Outer on the Edit Join screen when
you join the JobAsmbl table to the JobOper table. If you want a stepped
structure, sort & group by Job then Asmbl then Oper. The output should look
like this:
Job
Assy
Oper
Oper
Assy
Assy
Oper
If you forget the Left Outer check, then all Assemblies lacking opers will
be missing.
Good Luck,
Greg Krumrey, Information Manager, Patriot Machine, Inc.
Voice: 636-940-1776 x 130, fax: 636-940-8933
email: mailto:greg.krumrey@...
Alt: mailto:greg@... Web: www.patriot-machine.com
Sent: Tuesday, September 17, 2002 7:27 AM
Subject: [Vantage] Report - Job Assemblies with No Operations
I am looking for help creating a report which lists all the assemblies on
the Job, and the status of the associated operations. The key is that I
want assemblies to print out even when there are NO operations under it.
Thanks.
Amy
Amy T. MacKay
Engineering Manager
Parkinson Technologies
amackay@...
(p) 401-762-2100 x 324
(f) 401-762-2295
like this:
Job
Assy
Oper
Oper
Assy
Assy
Oper
be missing.
Good Luck,
Thanks.
Amy
Amy T. MacKay
Engineering Manager
amackay@...
(f) 401-762-2295
