Report Question
I went Into the report Data Definition Created a duplicate and Added
Numbers 01 up to number20 to the JobHead Included Fields. I then
went to the Job Job Traverler Report Data Set and put the Report
Style to the Data Definition that I just Created. I then Printed a
Traveler with the new data set to create my xml file. I opened up
crystal reports and opened the JobTraveler. I went to the the
datasource and Searched out the xml File that was just created. I
then Updated and closed. I look in my field explorer and not all
the fields that I added at the report data set is there. It stops
at Number11 and does not show 12 through 20 for jobhead.
--- In vantage@yahoogroups.com, RSN <rsnsfi@...> wrote:
> Michael, Your question isn't very clear. Could you provide more
detail about what you did - adding numbers 01 to 20. I'm sorry I
didn't understand what you did using the job traveler exactly.
> RSN
> ----- Original Message ----
> From: Michael McWilliams <mmcwilliams22@...>
> To: vantage@yahoogroups.com
> Sent: Tuesday, July 3, 2007 7:23:05 AM
> Subject: [Vantage] Report Question
> Using the job traveler I have added Numbers 01 to 20
> I set the report style with the definitions and print.
> Then I set the datasource in Crystal and it only shows number 01
to
> number 11??? Support won't help because it is a "Customization" .
_____________________________________________________________________
_______________
> Moody friends. Drama queens. Your life? Nope! - their life, your
story. Play Sims Stories at Yahoo! Games.
> http://sims.yahoo.com/
Working on a report that gives us all of our open MakeOver Jobs
currently in the shop.
MakeOver job is just a job where we had to scrap materials in house.
What I am trying to do is put on the report the qty of boards running
throught he shop. The problem is that with the following tables
involved in the report: JobHead, JobProd, JobAsembl,LaborDtl, and
Customer, I only seem to be able to pull Qty from the orderqty in
OrderDtl, or prodqty in jobprod. The numbers just aren't right, as
the orderqty is pulling the original orderqty amount, not the make
over amount....any ideas of where else I could look.
Steve
Before I go ahead and create this report, is there anyone that has already
created a report that would show $$ due per month based on aging POs.
Forgive me if I said that wrong, but what I have been asked for is a report
that shows when the $$ will come due for the POs we are entering now and in
the recent past.
Anyone???
Thanks in advance.
Aaron Hoyt
Information Systems Manager
Design Standards Corp.
PO Box 1620
Charlestown, NH 03603
Tel 603-826-7744
<mailto:aaron.hoyt@...>
Aaron,
We use a similar report using Crystal.
We link these tables:
-Company
-PODetail
-PORel
-POHeader
-Vendor
and use these fields:
-PORel.PONum
-POHeader.OrderDate
-PORel.DueDate
-Vendor.Name
-POHeader.EntryPerson
-PODetail.UnitCost
-PORel.RelQty
Rodney Warwick
The Signcraft Group
Sent: Tuesday, November 26, 2002 2:18 AM
To: 'Vantage E-Group (E-mail) ' (E-mail)
already
POs.
report
and in
the recent past.
Anyone???
Thanks in advance.
Aaron Hoyt
PO Box 1620
Tel 603-826-7744
------------------------ Yahoo! Groups Sponsor
Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must have already linked your email address to a yahoo id to enable access.
(1) To access the Files Section of our Yahoo!Group for Report
Builder and Crystal Reports and other 'goodies', please goto:
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Then I set the datasource in Crystal and it only shows number 01 to
number 11??? Support won't help because it is a "Customization".
Michael, Your question isn't very clear. Could you provide more detail about what you did - adding numbers 01 to 20. I'm sorry I didn't understand what you did using the job traveler exactly.
RSN
____________________________________________________________________________________
Moody friends. Drama queens. Your life? Nope! - their life, your story. Play Sims Stories at Yahoo! Games.
