I've worked with interactivity between Vantage and Access quite a bit. It seems to me that it should be fairly simple to set up a query in Access based upon certain CustNum on your Packing Slip tables that are related to your work. The key would be to automatically print this out. Would this need to be done on just a daily basis, or immediately after the packing slip prints? If daily, you can schedule a daily task on MS Access and I can help you with some of the process there. If immediately after the packing slip prints, then I'm not certain what to do to help. If you can find a VBA guru, they may be able to tell you what could be possible there.
Tony Leninger
Tleninger@...
Tony Leninger
Tleninger@...
