Report Security in 8.0
James,
I agree, it doesn't seem like the best design decision to have it work that
way and it does take some work to secure with the OS. It also makes more
work for the server admin as they have to remember to secure the new folders
every time they setup a new user. I don't have a doc number and I don't
know if they've even updated it for v8 yet, but here's a link to the
document I was referencing on EPICweb.
https://epicweb.epicor.com/SupportVantage/Resources/Documents/topntsecurity4
00.aspx
If anyone has a script that automates setting the permissions please share
it with the group.
Good luck,
Dan Snyder
IT Manager
Mercury Electronics
717-854-9557 ext.224
jameswi2000
Sent: Monday, November 14, 2005 11:00 PM
Subject: [Vantage] Re: Report Security in 8.0
Thanks Dan.
I'll have to ask support for this doc. By chance, do you know a doc number?
Also, I know I can secure them using the OS, but Crystal (or Vantage) is
creating the user subfolders dynamically, and they are inheriting the
permissions of the parent Report folder. I suppose it is posssible to
create the folders ahead of time, and lock them down.
Seems like a lot of work to do it this way, though.
James
--- In vantage@yahoogroups.com, "Dan Snyder" <sysadmin@m...> wrote:
> James,
> You should be able to secure the reports folders via your servers
operating
> system. I believe Epicor support has a document to help with this.
> Hope that helps,
> Dan Snyder
> IT Manager
> Mercury Electronics
Behalf Of
> jameswi2000
> Sent: Sunday, November 13, 2005 3:40 PM
> Subject: [Vantage] Report Security in 8.0
> Doe anyone know if Epicor plans to implement any type of security
for
> reports in version 8.0? Since everyone has access to the server
share where
> the reports/data are saved, anyone can browse any report that has
been run
> and not yet removed.
> Thanks,
> James
Doe anyone know if Epicor plans to implement any type of security for
reports in version 8.0? Since everyone has access to the server share
where the reports/data are saved, anyone can browse any report that has
been run and not yet removed.
James
James,
You should be able to secure the reports folders via your servers operating
Hope that helps,
Dan Snyder
IT Manager
Mercury Electronics
jameswi2000
reports in version 8.0? Since everyone has access to the server share where
the reports/data are saved, anyone can browse any report that has been run
James
Thanks Dan.
number?
is creating the user subfolders dynamically, and they are inheriting
the permissions of the parent Report folder. I suppose it is
posssible to create the folders ahead of time, and lock them down.
James
> James,
operating
> Hope that helps,
> Dan Snyder
> IT Manager
> Mercury Electronics
Behalf Of
> jameswi2000
for
share where
been run
> Thanks,
> James
