Report Style missing after updating to V 8.03.407c
Just to clarify..in case were not speaking on the same terms..i was
referring to the original report style and not the crystal report
itself. Im not sure screen shots work here but ill include one below
just in case.
What we experienced during an update is in each report ID there are
multiple styles and each comes with a style named 'Standard'. If we
modified this it was usually overwritten back to its original
configuration, and Ive also seen where it blew away any additional ones
in there as well. If the 'standard' style is left intact and just
inactivated it left everything else alone.
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of vistapdmmatt
Sent: Wednesday, May 27, 2009 4:00 PM
Subject: [Vantage] Re: Report Style missing after updating to V
8.03.407c
Rob,
The original standard report was never changed. All of our custom
reports are tweaked copies of the original...which are then set as
default.
This is why I'm so concerned. Why would a report style disappear during
an upgrade? Odd.
Matt
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Rob
Bucek" <rbucek@...> wrote:
> If you replaced the original standard report style with your own, it
> will smoke it. Leave the Standard one in place and create an
additional
> new one and make that the default.
> Rob Bucek
> FAX: 715-284-4084
> <http://www.dsmfg.com/ <http://www.dsmfg.com/> >
Behalf
> Of vistapdmmatt
> Sent: Wednesday, May 27, 2009 3:46 PM
> Subject: [Vantage] Report Style missing after updating to V 8.03.407c
> We updated to 8.03.407c last week and for the most part, everything
went
> well. We are running on Progress and Windows Server 2008 - 64 bit.
> Yesterday we tried to invoice and our custom crystal report was not
> showing up. After doing some digging, I found out that the Report
Style
> was missing completely, as though it were deleted from the database.
The
> other styles were intact, and the report was in the correct folder.
> Any ideas?
> Thanks,
> Matt
We updated to 8.03.407c last week and for the most part, everything went well. We are running on Progress and Windows Server 2008 - 64 bit.
Yesterday we tried to invoice and our custom crystal report was not showing up. After doing some digging, I found out that the Report Style was missing completely, as though it were deleted from the database. The other styles were intact, and the report was in the correct folder.
Any ideas?
Matt
will smoke it. Leave the Standard one in place and create an additional
Rob Bucek
FAX: 715-284-4084
Of vistapdmmatt
Any ideas?
Matt
Rob,
The original standard report was never changed. All of our custom reports are tweaked copies of the original...which are then set as default.
This is why I'm so concerned. Why would a report style disappear during an upgrade? Odd.
Matt
> Rob Bucek
> FAX: 715-284-4084
> Of vistapdmmatt
> Any ideas?
> Thanks,
> Matt
407 added more reports to the menu, so if yours was the third in the list it
was over written by the new addition. I added a fake report to 406 version
so when the patch was installed my reports were still on the list.
Steve
Sent: May 27, 2009 4:00 PM
Subject: [Vantage] Re: Report Style missing after updating to V 8.03.407c
Rob,
upgrade? Odd.
Matt
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Rob
> Rob Bucek
> FAX: 715-284-4084
> <http://www.dsmfg <http://www.dsmfg.com/> com/>
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
> Of vistapdmmatt
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Any ideas?
> Thanks,
> Matt
