# Report XML name **Category:** [Epicor ERP 10](https://www.epiusers.help/c/e10/5) **Created:** 2017-02-07 20:32 UTC **Views:** 912 **Replies:** 3 **URL:** https://www.epiusers.help/t/report-xml-name/37187 --- ## Post #1 by @duckor Does anyone know how to retrieve the number in the XML's created in the reports\user folder before the xml is generated? For example the generated file name is "AR Invoice Form**09998**.xml" but the trace does not hold 09998 anywhere in it. I want to be able to know what the 09998 portion will be before the file is created to make a file system watcher filter for that specific file. Thanks! --- ## Post #2 by @kennethahayes It seems to be an auto-increment number that comes from Ice.SysSequence (where Name = TempFileNum). However, as far as I know, that doesn't get tied back to anything concrete that would allow you to identify a particular invoice, etc. --- ## Post #3 by @aidacra ice.sysrptlist.filename stores the full path to the generated XML file. This is after it is successfully generated, however. \\servername\EpicorData\Reports\epicor\BAQ Report68925.xml --- ## Post #4 by @duckor Thanks guys. That was very helpful but I do not think I can tie that in since I need it before they are generated, but I think I figured out another way. At least I learned something new! --- **Canonical:** https://www.epiusers.help/t/report-xml-name/37187 **Original content:** https://www.epiusers.help/t/report-xml-name/37187
