Yes,
I’ve been working on other things and planned on coming back to this. The yield recalculation does work, but I have to do some more testing to make sure I fully understand the outcome. What I’m finding is the labor ticket still shows the total with the scrap, but after the yield recalculation process, the operation in the job only shows the adjusted “good” amount with no record of the scrap.
Maybe that’s the way it’s going to be, which is fine, but I haven’t fully tested the process and evaluated the results.
Hi @Doug.C,
after yield runs, the calculated scrap qty (i.e. results) should appear here, thereby you should be able to compare/check the Run, Original, and Scrap Qty for each operation.
That’s something I wanted to explore. This is on the operation now:
Here’s the labor ticket:
The job was originally for 200.
There may be some checkboxes that I’ve ticked that makes this happen rather than showing the scrap on that operation.
is this after yield process run? i am assuming that all the required set up flags in place ?
