# Reports **Category:** [Yahoo Archive](https://www.epiusers.help/c/yahoo-archive/9) **Created:** 2000-08-08 16:46 UTC **Views:** 651 **Replies:** 12 **URL:** https://www.epiusers.help/t/reports/708 --- ## Post #1 by @system
I for one was unaware you could buy source for just the reports. That is a
good thing. However, buyers beware, programming in provision is much more
involved than Report Builder or Crystal. Many of the reports furnished
through Vantage use temporary tables based on various joins. In some
instances the data you want to add may require added tables and logic. This
is not a simple task. If you are not a "Professional Programmer" or take
some extensive training (A single week long class won't cut it) I would pay
the man or find a work around in crystal, report builder or try the EBI
module.
My two cents...
Keith
Sent: Tuesday, August 08, 2000 4:23 PM
To: 'vantage@egroups.com'
Cc: L-Sales-Vantage CAMs; Tim Ligas; Matthew Christus
Subject: RE: [Vantage] Reports
Todd is on the right track, but let me clarify. If you want source code for
Vantage, you must purchase it for the entire system. However, you may
purchase the Source Code for Reports only. They are sold by module. For
instance, you can purchase the source code for all the reports within the
Job Management module for a fixed price. This price is the same whether you
want to modify one report or all the reports within a given module. Please
contact myself or your specific Customer Account Manager off list for
details and pricing.
Michael Holton
e p i c o r S o f t w a r e
Manufacturing Systems
(800)638-3208 Ext. 5242
www.epicor.com
--- ## Post #2 by @system
If they are crystal reports, yes, you can use crystal. If they are progress
reports, no, from my understanding.
Greg
Sent: Tuesday, August 08, 2000 12:33 PM
To: vantage@egroups.com
Subject: [Vantage] Reports
Hi all,
is there a way to load the reports, which come standard with Vantage,
into the reportbuilder or Crystal ?... i want to see the fields and
tables they use.
Hendrik
--- ## Post #3 by @system
Three types of reports exist with Vantage
1) Crystal reports: Located in the "userform" directory in Vantage.
2) Report Builder: "Reports" library in the main directory of Vantage.
Epicore does not have any standard report in report builder.
3) Progress Reports: You can not access them unless you have the Vantage
source code.
Martin Nijdam (Jr. Ing.)
Suss Woodcraft Int'l
(514) 363-3565
> From: Hendrik Stasik [SMTP:hstasik@...]
> Hi all,
> tables they use.
> Thanks
> Hendrik
--- ## Post #4 by @system
Well,
I do not know if they are Crystal or Progress, I do not know where they are
located, inside a library ? folder ? file ?
for better understanding I mean the reports in, for example,
Job Management
Master File Maintenance
General Operations
Reports---->
Hendrik
Greg
Hi all,
tables they use.
Hendrik
--- ## Post #5 by @system
I do not have a folder/library "Reports" in my main Vantage(4) directory...
Hendrik
source code.
(514) 363-3565
> Hi all,
> tables they use.
> Thanks
> Hendrik
--- ## Post #6 by @system
The reports you are referring to are the Vantage Progress reports and there
is no way to access the code modify them, or view them in another program
(unless you have provision, then you can access them and modify them).
Your report builder reports may be in the Vantage -> UD folder rather than a
reports folder.
--- ## Post #7 by @system
Sorry but this is not entirely correct. The reports are indeed written in
Progress 4gl code using ProVision. However unless you licensed the source
code you CAN NOT view or modify the source code behind them. You can hire
our favorite group Custom Programming or purchase source code and
write/modify your own.
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Tuesday, August 08, 2000 2:14 PM
reports folder.
--- ## Post #8 by @system
You can access progress reports withough the source code? I would love to
know how.
(514) 363-3565
> From: sarah.vareschi@... [SMTP:sarah.vareschi@...]
> there
> a
> reports folder.
--- ## Post #9 by @system
Hendrik:
Look in System Utilities, Report Style Maintenance. This gives a list of
all "canned" reports (they came from Vantage). It indicates whether the
default report is a Progress report (that you can't reach), or a Crystal
Report-which you can modify. If you edit this list, it will show you where
in the Vantage directory your reports are stored. My experience is that the
Crystal Reports are usually in Vantage\USERFORM\ and then the name. A word
of caution: If you alter any canned Crystal Reports, save them under a new
name, or they could be wiped out when you upgrade to another version of
Vantage.
Report Builder Reports are in a library: it is usually
Vantage\UD\Vantage.PRL
Hope this helps.
Lydia
Sent: Tuesday, August 08, 2000 10:59 AM
Hendrik
source code.
(514) 363-3565
> Hi all,
> tables they use.
> Thanks
> Hendrik
--- ## Post #10 by @system
"The reports are indeed written in
code you CAN NOT view or modify the source code behind them."
Wow, I can't believe that purchasing the progress provision tools does not
give you access to modify those reports. I really thought that was the
case, I'm bewildered as to why Epicor would only allow you to modify or view
progress reports with source code, but I'm sure that is indeed the case.
Common sense led me in the wrong direction this time:)
--- ## Post #11 by @system
Yes, it probably is a MOOT point at this time isn't it?
______________________________________________________________________
This document should only be read by those persons to whom it is
addressed and is not intended to be relied upon by any person without
subsequent written confirmation of its contents. Accordingly, PRECISION
MACHINE AND MANUFACTURING COMPANY disclaims all responsibility and accepts
no liability, including in negligence, for the consequences for any person
acting, or refraining from acting, on such information prior to the receipt
by those persons of subsequent written confirmation.
If you have received this E-mail / Fax message in error, please notify
PRECISION MACHINE AND MANUFACTURING COMPANY immediately by telephone.
Please also destroy and delete the message.
Contact:
By Phone: Systems Administrator at (515)-733-5181
By Email: sysadmin@...
Any form of reproduction, dissemination, copying, disclosure,
modification, distribution and/or publication of this E-mail / Fax message
is strictly prohibited.
--- ## Post #12 by @system
You want to talk about source code purchasing.
We purchased the code for the Gateway module so
that we could develop and enhance data collection
as we saw fit. Yes we received the code, however,
this does not include the licenses for any add-on
OCX's that Epicor is using. When you open the code
in provision, if you do not have the license
file you will receive an error message and then
Provision will remove the control from the module.
So now if you save and recompile it with out the OCX,
have fun!
Michael Podlin
Sent: Tuesday, August 08, 2000 1:37 PM
Sarah,
You're on target.
You can purchase :
1. Vantage
2. Vantage Source Code
3. ProVision.
If you purchase Vantage Source Code AND ProVision you can modify the
"Standard" programs that come with Vantage. If you purchase ProVision but
do NOT purchase Vantage Source Code you can write your own programs outside
of Vantage but cannot change any of the existing programs.
I don't know how EPICOR handles source code sales these days but it use to
be that you could purchase the source code on a module by module basis. So
common sense should dictate that you be able to purchase the source code for
JUST the reports for a very reasonable amount of money.
It's probably a mute point to even say this but would ANY of the EPICOR
people on this list care to chime in here ?
Todd Anderson
Sent: Tuesday, August 08, 2000 1:29 PM
--- ## Post #13 by @system
Michael Holton
www.epicor.com
Sarah,
You're on target.
You can purchase :
1. Vantage
3. ProVision.
Todd Anderson
--- **Canonical:** https://www.epiusers.help/t/reports/708 **Original content:** https://www.epiusers.help/t/reports/708
