Repost- please help with a script editor question
Thanks so much Stephen! I got it to work with your help!
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...> wrote:
> Basically to access pre-defined (native) controls you need to use the
> following syntax
> Csm.GetNativeControlReference("Guid-Of-The-Control")
> You can then cast this into the specific control Type and access its
> properties.
> However, if you are reading the value of the control, you should really
> be utilising the EpiDataView.
> Looking in the object explorer will give you an example of how to access
> these.
> The EpiDataView is simply a wrapper to the DataView object.
> Hope this helps
> Regards,
> Stephen
> Of unackvi
> Sent: 10 March 2009 17:01
> To: vantage@yahoogroups.com
> Subject: [Vantage] Repost- please help with a script editor question...
> In the VB Script Editor on one of my Invoicing sheets:
> I am trying to see whats in my txtSoldToCustID field on the screen but I
> can't
> access it as easily as I can the Custom text control which is just using
> its
> name e.g. txtOnHold.Name
> I get an error message for the pre-defined text control if used by its
> name e.g.
> txtSoldToCustID.Value
> Do I need to reference it somehow?
> Please let me know if there is more info needed from the properties of
> the two
> controls in order to answer my question.
> This is probably an easy one but I am a newbie to this world!
> Thanks in advance!
I am trying to see whats in my txtSoldToCustID field on the screen but I can't
access it as easily as I can the Custom text control which is just using its
I get an error message for the pre-defined text control if used by its name e.g.
Please let me know if there is more info needed from the properties of the two
Thanks in advance!
following syntax
properties.
these.
Hope this helps
Regards,
Stephen
Of unackvi
can't
its
name e.g.
the two
Thanks in advance!
