Request a move from a job - 8.03.404
I believe there should be a Move WIP Request button under the Production
tab on your MES screen. This is also available under advanced material
management tab under production management\data collection. This
assumes of course you have AMM..there is also an option of setting your
system up to automatically create those move requests, taking the burden
off the operator to generate it, and your supervisor to fix it (albeit
incorrectly).
Of Ed Garbowski
Sent: Wednesday, July 15, 2009 8:31 AM
Subject: [Vantage] Request a move from a job - 8.03.404
If a final op is completed on a job and the operator does not request a
move to place his parts in the material queue, our shop supervisor is
clocking back in on the job, adding one to the quantity completed and
requestiong a move. This is causing problems in that there will be a
remaining quantity still sitting in the queue after the actual quantity
is moved.
This can't be the right way to solve his problem, but can anyone tell me
what is the right process he should follow?
Ed
If a final op is completed on a job and the operator does not request a move to place his parts in the material queue, our shop supervisor is clocking back in on the job, adding one to the quantity completed and requestiong a move. This is causing problems in that there will be a remaining quantity still sitting in the queue after the actual quantity is moved.
This can't be the right way to solve his problem, but can anyone tell me what is the right process he should follow?
Ed
