Required to reboot server to restart database
Our DB is 7GB in size, we have 50 client machine connects, and 2008 x64 running with 8GB RAM.
Here's what our mfgsys.pf start-up looks like:
-Mm 1024 -mmax 65534 -Bt 4096 -s 215 -yy 1970 -stsh 31 -inp 32000 -tok 4000 -TB 31 -TM 32 -D 500 -l 1000 -ttmarshal 5
-T c:\epicor\mfgwrk803
-db c:\epicor\mfgsys803\db\mfgsys
-cpinternal utf-8 -cpstream utf-8 -cprcodein utf-8
--- In vantage@yahoogroups.com, Michael Barry <mbarry@...> wrote:
> I've seen this happen if you set your -B too high as well.
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
> http://www.aspacia.com/
> On Jun 1, 2012, at 9:38 AM, James Todd wrote:
> > Sounds like maybe you have some bad ram. I'd suggest running memtest86.
> > -J
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of sanfranc415
> > Sent: Friday, June 01, 2012 9:36 AM
> > Subject: [Vantage] Required to reboot server to restart database.
> > Our database OpenEdge10.1b has always had problems, but recently it has gotten has bad that the Mfgsys803 Database will not start back up unless the server is completely rebooted.
> > When trying to restart the database it mentions something about being stuck in memory.
> > What's database utilities do you recommend are run to help resolve this issue?
> > --sf
> > ________________________________
> > Technical information contained in this e-mail may be controlled by the United States Government, Department of State, International Traffic and Arms Regulations (ITAR) (22 CFR 120-130) which requires an export license prior to sharing with foreign persons. Lacking such license, ITAR technical data is limited to U.S. persons only. It is the responsibility of the organization and the individual in control of this data to abide by U.S. Export Laws. If you are not a U.S. person take no further action with this e-mail and contact sender immediately.
--sf
-J
--sf
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
> -J
> --sf
-BT = 4096
Blocks in Database Buffer: 20000
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
> > -J
> > --sf
You mean the -Bt? Our is set to "4096" The buffers our also set to 1024.
--sf
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
> > -J
> > --sf
