It is my understanding that Multi-Plant and MRP does not function
properly in 403C - Monte Tomerlin
--- In vantage@yahoogroups.com, "mustardbuzzards" <c.edwards@...>
wrote:
>the
> For those using multi-plant and requisitions read on!
> Summary:
> PM Bug: Requisition not using correct plant
> Description / Steps to reproduce:
> Page Number
> 26881MPS
> Problem Description
> When creating a requisition and changing plants to approve and
> submit it for purchasing this process is changing the plant that
> po is for.Mpls
> Program ID
> Purchase mgmt
> Software and Database Info
> Vantage - Tecato/8301
> Steps to Duplicate
> log on as manager/manager
> step 1 Go to options and change plant and make sure your in the
> plantgive
> step 2 Prodction mgmt>Job mgmt>General ops>Job entry
> step 3 Go to file new and new job and take the next job number and
> Ok and make note of it
> step 4 In the part field enter dcd-100-sp and tab and give it a
> required by date and save
> step 5 Go to file new and new demand link and make to stock and
> a qty of 5 and savetab
> step 6 Right click on the operation and add and click on the drop
> down and search and select one and save
> step 7 Right click on material and add and add a purchase part and
> give it a qty/per parent of 1 and save
> Step 8 Go back to the job tab and engineer and release the job and
> and go to actions and schedule and job schedule and OK and save.
> step 9 Material mgmt>Purchase mgmt>General ops>Requisition entry
> step 10 Go to file new and new requisition and select a requestor
> and save and make note of your number
> step 11 Go to file new and new line and go to the line and detail
> step 12 Click on the job button and enter your job that you createdlist
> above
> step 13 Enter in a non part master part and give it a description
> and choose a class and enter a qty of 5
> step 14 Click on the supplier button and choose one and enter in a
> unit price ie 50.00 and save
> step 15 Click on dispatch requisition and select forward and click
> on your action choose a dispatcher ie system mgr and OK
> step 16 Click on dispatch requisition and click on approve/submit
> and select the action and the dispatcher system mgr and Ok
> step 17 Click on the to do list and it should now appear in this
> step 18 Production mgmt>Job mgmt>General ops>Job entryand
> step 19 Pull you job up that you created and unengineer and release
> your job and save
> step 20 Go to options change plant and select the St. Paul plant
> OKhas
> step 21 Material mgmt>Purchase mgmt>General ops>Reqisition entry
> step 22 Click on the binaculars and search and select yours and OK
> step 23 Click on dispatch requisition and select approve/submit and
> for action select create purchase order and OK
> step 24 Material mgmt>Purchase mgmt>General ops>Generate purchase
> order
> step 25 Click on regenerative and process and go to the status
> monitar and see when the process is complete
> step 26 Material mgmt>Purchase mgmt>General ops>New po suggestions
> step 27 Click on the binaculars and search for your and OK
> step 28 Make sure a buyer is selected and check the box for buy and
> save
> step 29 Go to actions and generate purchase orders and for this
> buyer and OK
> step 30 Material mgmt>Purchase mgmt>General ops>Purchase order entry
> step 31 Click on the binaculars and search by the buyer from
> suggestions and find the one that was created
> step 32 Go to the release deatail tab and you will see the plant
> changed to St. Paul when it should be Mpls
> Version Number
> 8.03.305K
> Additional Info
> Test in 8.03.403C and following the steps above get the same results
> Response from Development
> Workaround
> The only workaround is to make sure you approve/submit the
> requisition for purchasing in the plant it is created in. The only
> issue if you in another plant there is no way to tell what plant it
> was created in
