Resolve printing issues with a Zebra TLP2844
Thank very much James! your first suggestion worked. thank alot
--- In vantage@yahoogroups.com, "jameswi2000" <jameswi2000@y...>
wrote:
> I had a similar problem and changing the printer driver helped.
The
> latest Zebra Driver for this printer is the Zebra Universal Driver
> 5.4.6.16 located at
> http://www.zebra.com/id/zebra/na/en/index/drivers_downloads.html
> You can tell if you have this version becasue the properties
screen
> has an about tab. This driver is filled with cool stuff compared
to
> some of their older ones.
> Also, here are a couple ideas for the 90 degree rotation... You
> could try setting the default size to 4x2 instead of 2x4. You
could
> also try changing the orientation in either the driver or the
report
> to landscape instead of portrait or vice versa.
> Hope this helps!
> --- In vantage@yahoogroups.com, "bakerprovan" <bfindlay@t...>
wrote:
> > Does anyone know how I can rotate details 90 degrees to print
> > (Zebra TLP2844), as in Vantage 6.1 could not change the layout
> > format I've set. Because in the printer settings only allow 180
> > degrees rotation. I want to print with a 2"x4" label in this
> > format:
> > | gfasdfsf sdf sd fs fs fsfsfsffasfafsfsfd |
> > But prints it as rotated 90 degress:(dots represent blank spaces)
> > |.........ggfhghfshsfhdfdfgdfg.............|
> > Can anyone help?
format:
Can anyone help?
I had a similar problem and changing the printer driver helped. The
5.4.6.16 located at
You can tell if you have this version becasue the properties screen
has an about tab. This driver is filled with cool stuff compared to
could try setting the default size to 4x2 instead of 2x4. You could
also try changing the orientation in either the driver or the report
Hope this helps!
> format:
> Can anyone help?
