We are using the Epicor.Customization.EcfRuntime to create a Type Resolver, to dynamically create a type at, well, runtime. However, there is some inconsistent logic happening and I’m putting this out there while I work on it to see if anyone has encountered anything similar.
This is regarding CSF, namely AU and NZ functionality, so that’s what I’ll base this question around. With the following code, I am able to resolve the type to Epicor.Internal.EI.ARPayment_AU_ABA, however, it provides null for ARPayment_NZ_BNZ.
ICustomizationItemResolver<Type> resolver = EcfRuntime.Current.CreateTypeResolver(this.Db, "ElectronicInterface", null);
string fullyQualifiedClassName = string.Format($"{electronicInterfaceNamespace}.{Path.GetFileNameWithoutExtension(this.EFTHead.Program)}");
Type type = resolver.Resolve(this.Db, fullyQualifiedClassName);
Now if I use the filename instead, I have the opposite - my type is resolved to Epicor.Internal.EI.ARPayment_NZ_BNZ, however, null for ARPayment_AU_ABA.
Type type = resolver.Resolve(this.Db, Path.GetFileName(this.EFTHead.Program));
Has anyone experienced anything similar?
Cheers,
Dave.
