Resolved: Duplicate dropdown field on custom tab
I sent an email, but just incase.
could you please expand on your solution? I have a BAQCombo that grabs the RevisionNum for Parts. As you could guess, the BAQCombo grabs EVERY RevisionNum for EACH Part in the system. This is not practical. What I need the BAQCombo to do is grab ONLY the RevisionNums for the PartNum loaded on the screen.
I was wondering:
1.) how did you add criteria on the BAQ level and the customization level to make the BAQ results = Criteria from the Epibinding property?
2) is the "Customization to the Max" doc available anywhere?
Thank you!
--- In vantage@yahoogroups.com, "Jeff Greenaway" wrote:
> In case anyone else runs into a similar issue:
> Turns out the original field on the Contacts tab has some logic behind it
> that isn't visible or available to be copied to a new field.
> I resolved the issue by using a BAQCombo field and adding a criteria on the
> BAQ that limits results to CustID equal to the EpiBinding property on the
> new field. The process for adding this type of binding property criteria
> was part of the "Customization to the Max" session at InSights (for anyone
> who has that doc).
> Regards,
> Jeff
> Jeff Greenaway
> Consulting CIO/ERP Consultant
> jeffgreenaway@...
> www.cio-ondemand.com
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Jeff Greenaway
> Sent: Sunday, December 23, 2012 4:01 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Duplicate dropdown field on custom tab
> I've added a new tab to the CRM Call Entry screen and ran into a problem. I
> duplicated some of the Contacts tab fields (cust ID, cust name, contact
> name, email, phone, fax) and all are working fine except Contact Name.
> My new field, the dropdown for Contact name, shows names for ALL contacts,
> not just those for the customer on the call. It does not act the same as
> the field I duplicated The same field on the Contacts tab (a standard
> field) only shows the contact names for the customer on the call.
> I've verified that the properties are identical for both fields.
> Any suggestions?
> We are on 9.05.606A.
> Thanks!
> Jeff
> Jeff Greenaway
> jeffgreenaway@...
who has that doc).
Regards,
Jeff
Jeff Greenaway
jeffgreenaway@...
Jeff Greenaway
Any suggestions?
Thanks!
Jeff
Jeff Greenaway
jeffgreenaway@... <mailto:jeffgreenaway%40cio-ondemand.com>
