Getting 400 error using rest api on user defined tables. I have valid json but getting “Can’t de-serialize”. Works with just a few properties
"Company": "ROCELEC",
"Key1": "MC68HC000EIXX-G",
"Key2": "RE-P-0",
"Key3": "068PLRECUAG-BLB",
"Key4": "MC68HC000EIXX-G_RERE1C1-A",
"Key5": "NA-NA-RERE1C1",
"PackageTechnology_c": "Plastic",
"PartNumber_c": "MC68HC000EIXX-G",
"EpicorPartRev_c": "RE-P-0",
"NewEpicorPartRev_c": "RERE1C1",
"PkgCode_c": "068PLRECUAG-BLB",
"AssemblyDocumentName_c": "MC68HC000EIXX-G_RERE1C1",
"AssemblyDocumentNumber_c": "ASP01441",
"AssemblyDocumentRev_c": "A",
"TestDocumentName_c": "NA",
"TestDocumentRev_c": "NA",
"Die1DieMfgr_c": "Rochester Electronics",
"DieAttachMaterial1_c": "8361J",
"LeadFinishRequired_c": "YES",
"LeadFrameType_c": "NA",
"LeadTrim_c": "YES",
"MarkTypeDetailed_c": "LASER MARK AFTER TEST",
"SealType_c": "MOLD",
"BumperTapeRequired_c": "NO",
"ClassType_c": "C",
"PkgDescription_c": "068 LD PLCC, Standard",
"DieAttachMethod1_c": "EPOXY",
"LeadFinishMaterial1_c": "100% Matte Tin",
"LeadFramePartNumber_c": 500012,
"MarkType_c": "Laser",
"PkgFamily_c": "PLYB-245",
"PkgGroup_c": "PLY",
"GenericPkgCode_c": "068PLRECUAG",
"PkgOption_c": "Standard",
"PkgOptionCode_c": "A",
"PkgType_c": "PLCC",
"PkgTypeCode_c": "PL",
"PkgVolumemm3_c": 2228,
"ActionYieldLimit_c": 0,
"SpecialInst_c": "After loading the program on the first run of the test program you will need to answer the following questions:&0x0A&0x0ATester User :&0x0A 1 - PRODUCTION &0x0A 2 - GATE &0x0A 3 - MAINTANANCE&0x0A 4 - ENGINEERING&0x0APlease Enter 1,2,3...&0x0AInput new Tester User : &0x0AEnter 1 for CLASS, 2 for QA&0x0A&0x0A&0x0AInput new Lot Number : &0x0A&0x0AEnter lot #&0x0A&0x0AProgram Flow :&0x0A&0x0A 1 - FHN (Enter for final test at HOT)&0x0A 2 - FRN (Enter for final test at ROOM)&0x0A 3 - FCN (Enter for final test at COLD)&0x0A 4 - QHN (Enter for QA test at HOT)&0x0A 5 - QRN (Enter for QA test at ROOM)&0x0A 6 - QCN (Enter for QA test at COLD)&0x0A&0x0A&0x0A&0x0ATarget Speed :&0x0A&0x0A 6 - 20MHZ&0x0A&0x0ATemperature :&0x0A(* select the temperature per CAMSTAR flow*)&0x0A&0x0A&0x0ATarget Device :&0x0A&0x0A 8 - MC68HC000EI20 &0x0A &0x0A&0x0AMask Number :&0x0A 1 - J82M&0x0A&0x0A&0x0AInput new Comment Message : Lot #&0x0A&0x0A&0x0ARun Bitmaps? :&0x0A 1 - NO &0x0A 2 - YES&0x0APlease Enter 1,2,3...&0x0AInput new Run Bitmaps? : 1&0x0A&0x0ALot Data&0x0A&0x0A it will summarize the answers. please answer y if correct or n to correct any error.&0x0A&0x0A",
"BinningInfo_c": "Bin 1: Pass 20 MHz&0x0ABin 4: Fail IDD&0x0ABin 5: Fail functional&0x0ABin 6: Fail gross functional&0x0ABin 7: Fail Leakage&0x0ABin 8: Fail Opens/Shorts",
"AssemblyFlow_c": "RE-05-C-PL",
"AssemblyLocation_c": "Rochester",
"BakeHours_c": "48 hrs",
"BodyLengthmil_c": 952,
"BodyLengthmm_c": 24.1808,
"BodyWidthmil_c": 952,
"BodyWidthmm_c": 24.1808,
"BodyThicknessmil_c": 150,
"BodyThicknessmm_c": 3.81,
"Carrier1PartNumber_c": "N/A",
"Clip1PartNumber_c": "N/A",
"PkgCodeStatus_c": "Active",
"CountryOrigin_c": "United States",
"Die1DieID_c": "ROCHESTER ELECTRONICS 03/2024",
"Die1DieMfgrShort_c": "RE",
"Die1SizeX_c": 145,
"Die1SizeY_c": 161,
"Die1BackgrindRequired_c": "Yes",
"Die1BackgrindThickness_c": "11 Mils",
"Die1WaferPrimaryU1PN_c": "S08D2CS35K23-ENG-WAFR",
"DieAttachCode_c": "C",
"JEDECDrawing_c": "MS-018-AE",
"JEDECDrawingRev_c": "A",
"FloorLife_c": "168 hrs",
"FootLength_c": "N/A",
"DieGoldPreform1PartNumber_c": "N/A",
"Handler_c": "Flex",
"JumperPartNumber_c": "N/A",
"LeadFinishCode_c": "G",
"LeadFrameCode_c": "B",
"LeadFramePrePlated_c": "Not Pre-Plated",
"LeadPitchmm_c": 1.27,
"LeadPitchmil_c": 50,
"LeadCount_c": 68,
"MfgrCode_c": "RE",
"MarkTypeCode_c": "L",
"MarkingLocation_c": "Rochester",
"MarkingTemplate_c": "PLCC-2",
"MoldCompound_c": "CV8213FRA",
"MoldCompoundCode_c": "U",
"MSL_c": 3,
"MSLBodyThkCode_c": "3C",
"Notes_c": "* = Selection (refer to marking instructions)&0x0AItems Shown Within the Orange (Background) Layer Should Not be Marked on Device and are to be Used for Orienting Part Relative to Pin 1.&0x0ASeal Date Code: YYWW",
"GenericPartNumber_c": "MC68HC000",
"PeakBodyTemp_c": 245,
"Pin1PkgOrientation_c": "Standard/Package Orientation Spec ASY706",
"Tube1PartNumber_c": "700006-2",
"PinPlug1PartNumber_c": "700007-2"
