Rest API - Required fields are null
Hi all,
I am trying to update/add new Inspection Result via Rest API.
When i do it via Epicor application I get blank field for File, Key4 and Key5 columns.
But when I try and do it via InspectionResultsvc/InspResultsCheckBoxes Patch method, the fields that are required are null and I am not too sure how to update it. I have tried passing null but that didnt work
Anyone has any suggestions please?
Anya
try 2 single quotes - ‘’ - empty string
@Olga is correct. That is one of the things that drives my inner DBA nuts - the use of empty strings instead of a null. It is a common pattern though throughout the product so get used to using it :slight_smile:
well, Primary keys cannot be null anyways, those are always empty strings.
Awesome thank you !
