REST Services / Sub Domain Capable
We have an Epicor 10.2.300 site that is running on an application server that is in a sub domain. The FQDN for the server is ...local. REST Services are enabled, and the certificate is working, however, when logging into the site it does not authenticate immediately. It requests username and password to login. However, a setup that I have on another server with an FQDN of ..local does not do this. It automatically logs into the REST services site and lists the help details.
Does anyone know of any limitations on the sub domain option within the REST services API? The application server is setup the same between both servers. We are using single sign on within each application server.
Any thoughts or suggestions would be greatly appreciated!
do you have windows authentication enabled in iis that was missing when I was doing mine.
This was the issue. All is well now!
