REstful services in Service Connect
We have a clean install of the latest Service Connect (11.3.200) and I am using the restful services to access Kinetic.
I just added a UD field and the Prt_UD table. I did a rebuild of the data model. I have re-imported the Restful Services but don’t see the UD field.
Can someone tell me what I am missing?
If memory servers there is a tick box when importing the Restful services to include Ud columns.
There is for the .NET references, but not one I can see for the Restful services.
I see the following:
Use Service License (Checked)
Import OData
Import Custom Methods (Checked)
Import published Epicor Function libraries from current company
Continue Import on Error
Okay. If on-prem have you recycled all app server connected to the DB? If service connect is point to app server B and you only recycled app server a then B will not have the up to date schema to pull the UD field in.
Thank you, knew it must be something simple.
