Retrieve correct UOM conversion factor Using BAQ
I’m trying to pull data using BAQ which involving the UOM conversion. Could you please advise how I can get the correct UOM conversion factor?
For example Part A, the Part UOMs are as below:
Your picture did not come through, but you will need to convert the UOM from it’s current UOM to the Base UOM for that UOM Class, then to whatever the UOM you may want to show. This means linking the UOM table twice.
For example, you have the Length UOM with a Base UOM of inches. You need to show everything in feet, but your part is in centimeters.
Part > UOM (filtered for the default/base for the class) > UOM (filtered to the UOM you want to see).
Then the math is just a conversion equation based on the fields. I recommend not using hard-coded conversion in the BAQ.
