Retrieving Contact from ContactAdapter
Hi All,
I am trying to retrieve the key fields for a customer contact from the
Contact Adapter.
I save the results from the search window into a dataset but when I
iterate through the dataset it doesn't contain the contact number. I
need this in order to identify the contact.
It does contain CustNum.
This is the line of code I'm using to initiate the contact search.
Dim dsContactAdapter As System.Data.DataSet =
Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,
"ContactAdapter", recSelected, True, whereClause)
My expectation would be that the CustNum and the ConNum would be in the
dataset.
What am I missing?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-1264 | fax: 781-341-5694
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
