Return LaunchFormOptions
Thank you Jose that was exactly what I needed!
I currently have a screen that will use LaunchFormOptions and ProcessCaller to launch another form. I want to now take some data from the launched form and return it to the original screen. How would I go about returning the data from the launched screen?
Here is some of my code (C#):
This is for the screen that is launching the "POComp" form:
//add the part and lot to an array
string[] arr = new string[3];
arr[0] = partNum;
arr[1] = lotNum;
arr[2] = dmrNum;
//transfer the data to an external popup window
LaunchFormOptions ifo = new LaunchFormOptions();
ifo.ValueIn = arr;
ifo.ContextValue = null;
ifo.IsModal = false;
ifo.SuppressFormSearch = true;
object res = ProcessCaller.LaunchForm(oTrans, "POComp", ifo, true);
Thank you!
Its some what complicated, bt basically in your LFO
you set  a CallBackMethod such as
lfo.CallBackMethod = myPrivateMethod;
in your customization you handle said method
void myPrivateMethod(object sender, object CallBackArgs)
// verify there is CallBack args
if (CallBackArgs == null) return;
EpiMessageBox.Show("Customer form handles callback with message: Â " + CallBackArgs.ToString());
Then on the called Form,
You Address the Form.LaunchFormOptions.CallBackMethod(oTrans,"YOUR DATA HERE");
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
     Â
On Wed, Apr 23, 2014 at 10:10 AM, <gkoutre@...> wrote:
Â
<div>
  <p></p><p>I currently have a screen that will use LaunchFormOptions and ProcessCaller to launch another form. I want to now take some data from the launched form and return it to the original screen. How would I go about returning the data from the launched screen?</p>
arr[0] = partNum;
arr[1] = lotNum;
arr[2] = dmrNum;
ifo.ValueIn = arr;
Thank you!
</div>
<div style="color:#fff;min-height:0;"></div>
