Hi - I'm not sure if this is the issue, as I can't test it at present, but try going to the Revision>Detail tab, and against any/every revision, make sure these is some text (anything at all) in the Description field. Hit save.
Kerry.
Kerry.
--- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@...> wrote:
> I have some parts from a old conversion that contain "?" in the Part Description field. I'm unable to make any changes to the Part, because when I try to change anything, I get the error message:
> "Rev Description cannot be null."
> Details:
> Error Detail
> Message: Rev Description cannot be null.
> Type: Error
> Program: core/BizRuleEngine.p
> Method: ValidateField
> Table: Part
> Row: 0x000000
> Field: PartDescription
> Stack Trace
> at Epicor.Mfg.Proxy.PartImpl.Update(PartDataSet ds)
> at Epicor.Mfg.UI.Adapters.PartAdapter.Update()
> at Epicor.Mfg.UI.App.PartEntry.PartTransaction.AdapterUpdate()
> at Epicor.Mfg.UI.App.PartEntry.PartTransaction.UpdateX()
> This only happens to 40-50 old parts from a conversion. Currently we're using 8.03.406
