Rework of Serialized Part Numbers
I'm trying to follow your directions:
1) Create job to produce part "1234"
2) material for Job = "1234"
3) Issue material to job (including actual serial number in this case "013" is the serial number)
4) open serial number maintenance for part 1234, serial number "013", and change job/asm/seq for material from xxxx/0/10 to xxxx/0/0...
I must be doing it wrong because all I get is "Invalid Material Sequence"
--- In vantage@yahoogroups.com, "P" <pklein@...> wrote:
> We have a serialized part that we issue to a job, there might be materials and labor and then when that serialized part is received into inventory - we give it the same serial#. The weird trick is to go into serial# maintenance, change the job's material seq to 0, and then the person is able to do the receipt to inventory for that same serial#/part# combination. If you get an error in serial# maintenance when you try to change the material seq# - then change the job# to 0.. This will 0 out the material Seq# click save. and then you can put the job# back in.
> I'm not sure about the rev level, because our parts come out at the same rev level.
> --- In vantage@yahoogroups.com, "Douglas" <dgum@> wrote:
> > Yes part 1234, Rev C as material, Rev D as job output.
> > However, when completing the Job Epicor will not allow me to use the same Serial Numbers for the Rev D parts. It seems to insist on giving them new serial numbers.
> > --- In vantage@yahoogroups.com, "Nancy" <nhoyt111@> wrote:
> > > Can't you add the Rev C parts as material to the rework job to make the Rev D part?
> > > > I have 4 pcs in stock with serial numbers that were machined to Rev C of the drawing.
> > > > I need to issue a Job to do further machining to convert them to Rev D of the same drawing.
> > > > I want to end up with these parts being the same Part Number and the same Serial Numbers when I am done.
> > > > Anybody know how to do this using Epicor 905 ???
