RFQ Suggestions from Buy to Order
As long as the Part number is marked to generate PO Suggestions, the system will generate a PO Suggestion and there you can check the box Create RFQ.
Manasa
Sent: Thursday, October 30, 2014 5:17 AM
Subject: [Vantage] RFQ Suggestions from Buy to Order
Hi all,
Does the system work this way?
Example:
SO line created for part
Marked buy to order
How can you make the system generate a RFQ suggestion against the buyer on the Part.Plant?
Or is the only way to do this via a job linked to the line with a Purchase direct option ticked?
Andy
Hi all,
Example:
Marked buy to order
Andy
