Hi Sal,
I'm on 8.03.407 - maybe you are on a different version. I have used it
in a lot of BAQs and it works fine.
Linda
Of dciepicor
Sent: Tuesday, August 03, 2010 3:48 PM
Subject: [Vantage] Re: Right Justify Calc field on BAQ
Hi Linda,
My Data Type is Decimal as well and i don't have double quotes in the
Format. After I made the change in the Calc field I hit the Analyze and
Test buttons the the column data didn't change. I tried a couple of
other formats but nothing worked either.
"Linda Lowney" <llowney@...> wrote:
quotes.
Behalf Of dciepicor
it didn't seem to work. Am I doing something wrong? Thanks again for the
Reply!!
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]
On Behalf
Linda
Of dciepicor
Hi Linda,
>format in your email, did you put the quotes in the Format? Mine has no
> Hi Sal,
> My Data Type is Decimal, is yours? You show double quotes around the
quotes.
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Regards,
> Linda
Behalf Of dciepicor
> Sent: Tuesday, August 03, 2010 3:33 PM">>>,>>>,>>9.99". I too need two decimal point as well. I tried this but
> Hi Linda,
> Thank you for your reply. So in the Format field i enter
Reply!!
><mailto:vantage%40yahoogroups.com> , "Linda Lowney" <llowney@> wrote:
> -Sal
> ><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
> > Hi Sal,
> > Open the calculation and set the format. Here is one that I use that
> > has two decimals. >>>,>>>,>>9.99
> > Hth,
> > Linda
On Behalf
> > Of dciepicor<mailto:vantage%40yahoogroups.com>
> > Sent: Tuesday, August 03, 2010 1:17 PM
> > Subject: [Vantage] Right Justify Calc field on BAQadvance!!
> > Hello,
> > I have a BAQ that includes a Calc field. The data is returning the
> > correct figures however it is displaying Left Justified vs Right
> > Justified. Does anyone know how I can correct this? Thanks in
> >[Non-text portions of this message have been removed]
> > -Sal
