Thanks Charlie for both of your replies.
I'm going to change our process to return Kit components instead of the non-stock kit. We have been successful in creating an RMA for a non-stock kit so I don't know what is broken there. You would think we would not be allowed to process the RMA using the kit PN.
Dave
Dave
--- In vantage@yahoogroups.com, "ofcwiz" <DavidH@...> wrote:
> A non-stock kit is returned on an RMA. The components are accepted as good and must be returned to stock.
> The kit part number cannot be dispositioned to stock because it is not stocked.
> The components cannot be stocked because they do not exist on the RMA.
> If I change the RMA Line(s) from the kit part number to the components, the correct credit is not applied to the SO.
> Even an adjustment does not work because there is no place to move the kit to. I could just adjust the inv. Qty for the components.
> We need to get the components into stock.
> Has anyone had this problem and found a solution? Any suggestions would be welcomed.
> Thanks,
> Dave
> Xybix
> 8.03.407C P
