Gary,
If you can't adjust the decimals another trick is to multiply it so that digits you want are in the integer part, drop the decimal and then convert back to the decimals you need. You might need to do this to all components going into the calculation, do the math, drop the decimals from the result and then reconvert back.
Jim Kinneman
Encompass Inc
