Row rules in grid
You can do this use custom action
Sent from mobile
On May 13, 2011 7:21 PM, "ksimon8fw" <ksimon@...> wrote:
> Has anyone used the row rules in a grid to highlight the entire row? I'm
using the wizard, and have it highlight a field in the row. However, if I
want it to highlight the entire row, I don't see any way to do this other
than individually highlighting each field in the row.
> Also, has anyone experienced where the data changes, and the highlighting
doesn't. Example, suppose I've got 5 rows in my grid, and the data for the
2nd row highlights a field on the row. Then, I do something that changes my
data - I've got 4 new rows in the table. Sometimes the 2nd row field stays
highlighted when it doesn't meet the row rules. If I click on the field, the
highlighting goes away. I was wondering if anyone had a workaround to this.
> Thanks in advance,
> Kevin Simon
Has anyone used the row rules in a grid to highlight the entire row? I'm using the wizard, and have it highlight a field in the row. However, if I want it to highlight the entire row, I don't see any way to do this other than individually highlighting each field in the row.
Also, has anyone experienced where the data changes, and the highlighting doesn't. Example, suppose I've got 5 rows in my grid, and the data for the 2nd row highlights a field on the row. Then, I do something that changes my data - I've got 4 new rows in the table. Sometimes the 2nd row field stays highlighted when it doesn't meet the row rules. If I click on the field, the highlighting goes away. I was wondering if anyone had a workaround to this.
Thanks in advance,
Kevin Simon
