Row-Update does not update interface or dataview
I am currently using Epicor Application Studio using Kinetic 2023.1.12. I have taken the fundamental and advance course and this is my first attempt at customizing the kinetic screen:
  • PO Entry screen, PODetail
  • Customization built with Application Studio
  • Event triggered from a Command Button
  • Target field: PODetail.CommentText
  • Goal: Update the UI only and allow the user to press Save (no auto-commit)
What I have tried:
  • dataview-set-current is set correctly to PODetail
  • Confirmed event via App Studio debug + erp-message-handler
  • The correct row is current at runtime
  • row-update parameters:
  • EpBinding: PODetail.CommentText
  • Value tested with:
    • “testing”
  • Added event-row-enable before row-update
  • Still no UI change, no dirty state
  • Added data-commit after row-update
  • No effect
  • Verified:
  • The field value before update
  • row-update fires (no exceptions)
  • The row remains not dirty
  • No errors are thrown at any step
The PO being testing is Open and I am able to edit other fields and save them.
You should really only need a row-update action after the button click trigger. If you’re already on a PODetail (Line item) record, you shouldn’t need to set the dataview or the current row… you’re already on a specific PODetail record.
I agree. But I’ve tried almost everything. The only difference, is the PODetail.CommentText has been moved into a sliding panel. The column displays the pervious values when displaying a previous open PO.
is the sliding panel (Page) bound to anything?
Note the stock Purchase Order Line slide-out is bound to PODetail.POLine:
If your slide-out was also bound to PODetail.POLine, it may maintain the dataview/row for you.
Not sure of your set up and what all your displaying on the slide-out (assuming it is custom)?
The CommentText field has been moved.
Its in the same sliding panel as PODetail just moved down further within a dedicated text area.
Below is the debug/trace:
I can’t determine how this was fixed. Below is what I did:
  1. Moved the Comment section from below the “Full Screen” in designer to the top of the Details page.
  2. Saved
  3. Moved the Comment section below the “Full Screen”.
  4. Saved
  5. Previewed and magically it started to work.
