Cheers. I will give it a go.
Ross
Ross
On 30 Jun 2011, at 12:13, "Mike Anstey" <manstey@...> wrote:
> Haven't actually tried it, but here is some code I got a while back:
> Hi Mike
> I'm not entirely sure as I don't have an example to hand, but I'd guess
> at....
> parms.setStringParameter(6, errorFile, ParameterSet.OUTPUT)
> or
> parms.setStringParameter(6, errorFile, ParameterSet.INPUT_OUTPUT)
> ...then after runPersistentProcedure...
> Object o = parms.getOutputParameter(6)
> or
> Object o = parms.getParameterInOut(6)
> where 6 is the index of the output param in parms.
> Or if it's a procedure return value...
> Object o = parms.ProcedureReturnValue()
> Cheers
> Trev
> From: Mike Anstey [mailto:manstey@...]
> Sent: 19 January 2010 15:02
> To: Trevor Negus
> Subject: FW: Calling .p
> Hello Trevor, when calling a .p, how would you reference an output value
> from the .p? e.g. you want the program to return something you can then
> use as a variable in the screen.
> From: Anthony Knight [mailto:AKnight@...]
> Sent: Thursday, December 03, 2009 1:47 PM
> To: Mike Anstey
> Cc: Trevor Negus
> Thanks Trev ;)
> Once FB sign a WA, please feel free to send him any examples he requests
> which we have "to hand" . If we need to create one, let him know how
> long that will take and if he agrees, go for it ;)
> Ant
> From: Trevor Negus
> Sent: 03 December 2009 16:38
> To: Anthony Knight
> Subject: Calling .p
> ' Call a Progress procedure directly
> ' You need to include custom references to:
> ' Progress.o4glrt.dll
> ' Epicor.Mfg.AD.SysAgent.dll
> ' also the following imports:
> ' Imports Epicor.Mfg.Core
> ' Imports Progress.Open4GL.DynamicAPI
> ' then something like the following should work within your button click
> ' you'll see the last thing this does is call a refresh.
> Dim ThisSession As Epicor.Mfg.Core.Session = GLJournalEntryForm.Session
> Dim ThisProgressSession As Progress.Open4GL.DynamicAPI.Session
> Dim ThisPersistentProc As PersistentProc
> Try
> ThisProgressSession = ThisSession.ConnectionPool.Get()
> Dim parms As ParameterSet = New ParameterSet(6)
> '1 = group
> '2 = DfltDept
> '3 = DfltDiv
> '4 = DfltChart
> '5 = import
> '6 = errlog
> ' Save these so can set back (after screen gets "refreshed")
> Dim vcGlDept as string = txtGLDept.text
> Dim vcDivision as string = txtDivision.text
> Dim vcChart as string = txtChart.text
> Dim vcInputFile as string = txtInputFile.text
> Dim vcAccountCode as string = txtAccountCode.text
> parms.setStringParameter(1, txtGroupID.Text,
> ParameterSet.INPUT)
> parms.setStringParameter(2, txtGLDept.Text,
> ParameterSet.INPUT)
> parms.setStringParameter(3, txtDivision.Text,
> ParameterSet.INPUT)
> parms.setStringParameter(4, txtChart.Text,
> ParameterSet.INPUT)
> parms.setStringParameter(5, txtInputFile.Text,
> ParameterSet.INPUT)
> parms.setStringParameter(6, errorFile, ParameterSet.INPUT)
> ThisPersistentProc =
> ThisProgressSession.runPersistentProcedure("ud\GLImport.p", parms)
> oTrans.ClearDataSets()
> oTrans.Refresh()
> Catch ex As Exception
> MessageBox.Show(ex.Message)
> End Try
> Of Ross Robertson
> Sent: Thursday, June 30, 2011 4:45 AM
> To: Vantage Group
> Subject: [Vantage] Run 4GL code from vb.net app
> Hi,
> I was wondering if anyone has successfully been able to call a 4GL
> program on the server from a vb. NET app. Pass variables in and return
> data?
> I have been having a look at some documentation to do this but have not
> been able to get this to work.
> As a work around I can attach code to a bpm and get it to run, fill a ud
> table and retrieve but it's slow.
> Any help would be appreciated.
> Regards,
> Ross
