"Run Out" feature
When the "run out" box is checked on a part, it will only prompt you to
use a substitute. Vantage will only substitute a part (in the
configurator at least) if the part is marked inactive.
Regards,
Andrew Best
Kice Industries, Inc.
P(316)744-7151
F(316)295-2412
Of j.schwerer
Sent: Friday, May 16, 2008 8:39 AM
Subject: [Vantage] "Run Out" feature
We are in the electronics industry, and from time to time we would like
to use up a component from inventory and then switch to a new one. I
understand that run out will allow you to do this, but we're not sure
what happens when you actually "run out".
We are speculating that if you call out a substitute part from
inventory, it will somehow substitute the new part or flag you to do
so. Any explanation of the feature would be appreciated.
Joe Schwerer
IED Audio
Joe Schwerer
IED Audio
