Sent from my iPhone
On Jan 9, 2014, at 1:00 PM, "Len Hartka" <len.hartka@...> wrote:
Good Day:
I use Quick-Searches as a way to give USERS complex searches or reports\displays, since they cannot run BAQ’s that have not been converted to dashboards.
In 10 minutes, I can give them a very specific report with oddly related information and not have to clutter up, or deal with editing, the Menu Tree.
Can do the same with BAQ-Search – but it does not allow Prompts. Unfortunately, BAQ-Search will not execute an Updateable BAQ which is understandable since it needs file locking.
The items listed can be pasted into Excel to make a report or just viewed for information; for example: a quick PO-View that shows all lines, all deliveries, all released, and all invoicing for a specific PO-Nbr, OR a quick inventory report ( 10 seconds) – with age, demand, and usage.
Len
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Anthony Gercar
Sent: Wednesday, January 08, 2014 9:11 PM
To: <vantage@yahoogroups.com>
Subject: Re: [Vantage] RE: Running an Updateable BAQ
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.Why would you need an updateable quick search?
Sent from my iPhone
On Jan 8, 2014, at 7:59 PM, "Stephen Edginton" <stephene@...> wrote:
In short not in the ICE framework tools that are provided. Only via a dashboard.
You could make a customisation that called the uBAQ if required but really I don’t see why you would not just create the dashboard and publish that?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Len Hartka
Sent: 07 January 2014 19:00
To: 'vantage@yahoogroups.com'
Subject: [Vantage] Running an Updateable BAQ
Good Day:
Is there any way to run an updateable BAQ without using a dashboard?
I have used Quick-Searches and BAQ-Searches to get BAQ’s to users, but I just tried with an updateable BAQ and it did not work –it just ran as a query.
Could they be run using a UNC path from the Favorites menu tree?
Len
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Winter, Patrick
Sent: Tuesday, January 07, 2014 1:48 PM
Subject: RE: [Vantage] Updatable BAQ on PartTran.TranDate Field
FYI, an updatable BAQ did fix this.
Patrick
Sent: Tuesday, January 07, 2014 11:50
Her is a fun one. “Back to the Future – Epicor 9â€
Vantage 6 my rolling century on the database was 1960.
My conversion to Epicor 9 rolling century on the database is 1930
I have found a transaction dated for 2040 which I can’t do the 2 adjustment method you mention.
I can see the transaction with a BAQ I created but can’t run the Inventor y Quantity Adjustment on that date.
As soon as I enter 01/01/30 my Epicor 9 thinks I’m in the 19th century not the 20th.
I will have to Adjustable-BAQ-Hack this one out of the system.
Patrick Winter
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Miguel Santillan
Sent: Tuesday, January 07, 2014 11 :40
We run into this every so often…
We do exactly this.
Qty Adjust out of future dated receipt and Qty Adjust back in original date?
Miguel A. Santill an
Compass Manufacturing Systems
510-661-6666 Office
Sent: Tuesday, January 07, 2014 9:34 AM
I will give it a try, thanks.
Patrick
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Cathy
Sent: Tuesday, January 07, 2014 11:18
I believed I used an Updatable BAQ to change this before. It is the SysDate that you cannot update.
Subject: [Vantage] Updatable BAQ on PartTran.TranDate Field
I have a PUR-STK transaction from 10/17/08 entered as 10/17/14.
ISSUE: My TimePhase “Running Total†is off.
I’m thinking of creating an Updatable BAQ and changing the PartTran.TRANDATE field to the 2008 receipt date.
Has anyone done this?
How are others handling this?
Patrick Winter
