That was it!
Jasper
Sent: Tuesday, February 03, 2004 9:44 AM
Subject: RE: [Vantage] Running report from command line
Just a thought. Did you try putting it in the parameter file instead?
Here is the progress definition for error 301
Also when I run my batch files, I do not include the .db for the database path.
** Could not recognize argument: <string>. (301)
You entered invalid parameter. This is generally the result of a syntax error, such as omitting the minus sign in front of a parameter name. See the "PROGRESS Reference Manual" for a list of valid parameters.
S
Bart Sgroi
Sent: Tuesday, February 03, 2004 9:29 AM
To: Vantage Groups (E-mail)
Subject: [Vantage] Running report from command line
Hello all,
I wrote a procedure that runs all the reports in a certain library. I'm trying to create a batch file that will run this procedure. My command statement is below:
V:\PROGRESS\bin\prowin32.exe V:\VANTAGE\db\vantage.db -ininame V:\VANTAGE\vantage.ini -pf V:\VANTAGE\db\Vantage.pf -N TCP -H ntserver-S epic52 -ld vantage -p d:\ReportBuilder\ReportProcedures\BatchProcedure.p
Whey I try to run this, I get this error:
**Cannot recognize argument: -ininame. (301)
Any ideas on what this means?
Jasper
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cms1p24/M=268585.4464812.5643763.1261774/D=egroupweb/S=1705007183:HM/EXP=1075905010/A=1950447/R=0/*http://ashnin.com/clk/muryutaitakenattogyo?YH=4464812&yhad=1950447> click here
<http://us.adserver.yahoo.com/l?M=268585.4464812.5643763.1261774/D=egroupmail/S=:HM/A=1950447/rand=939166188>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Yahoo! Groups Links
Your use of Yahoo! Groups is subject to:
Jasper
S
Bart Sgroi
Hello all,
Jasper
ADVERTISEMENT
_____
Yahoo! Groups Links
Yahoo! Groups Links
