That was my first thought to make it on the job entry
But the problem with using the jobentry is that i cant make changes once the
job has been engineered.
I just need to update some custom fields
maybe there is a way to allow that ?
On Wed, Sep 7, 2011 at 11:15 AM, Brian Roberts <broberts@...> wrote:
> Do you have to start with the job closing screen? If you're just
> updating JobHead, then customize Job Entry like crazy, hiding everything
> you don't want, and then you've got the normal Update method. Add your
> customization as a new menu item.
> Brian.
> -----Original Message-----
> Of Ephraim Feldman
> Sent: Wednesday, September 07, 2011 11:03 AM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Running some VB code when saving a record
> No the JobMt and JobOper doesnt help me and i cant use the complete
> because
> i want basically have a flag that the order was picked and where the
> staging
> location is
> On Wed, Sep 7, 2011 at 10:59 AM, Brian Roberts <broberts@...>
> wrote:
> > There are a couple of OnChange methods (in the JobClosing BO). Can you
> > use the completed flag? I know the JobMtl & JobOper tables have the UD
> > fields available for display on that form, not sure if they'll be any
> > help to you.
> > Brian.
> Behalf
> > Of Ephraim Feldman
> > Sent: Wednesday, September 07, 2011 10:45 AM
> > Yes theere is a method but only when you actually Close the job but it
> > doesnt run otherwise.
> > Also i dont have custom fields to store info for the BPM to run on.
> > Ephraim
> > On Wed, Sep 7, 2011 at 10:26 AM, Waffqle <waffqle@...> wrote:
> > > I'm not an expert on Job Closing, but surely it must call SOME
> method?
> > Is
> > > Epicor really bypassing the whole BL layer?
> > > On Wed, Sep 7, 2011 at 10:04 AM, <effgroups@...> wrote:
> > > > I can't run a BPM on job closing since there are no custom fields
> to
> > use
> > > in
> > > > that program.
> > > > The job closing program is a different kind of program since it
> > doesn't
> > > > have a dataset based on a actual table so there are no custom
> fields
> > and
> > > > that's why I used controls not linked to a field and try to update
> > the
> > > > jobhead with code.
> > > > Ephraim
> > > > Ephraim Feldman
> > > > From: Ted Koch <tkoch77@...>
> > > > Sender: vantage@yahoogroups.com
> > > > Date: Wed, 7 Sep 2011 06:44:56
> > > > To: vantage@yahoogroups.com<vantage@yahoogroups.com>
> > > > Reply-To: vantage@yahoogroups.com
> > > > Did you try using a BPM to make these fields mandatory? That might
> > work
> > > > better if that's what you are trying to accomplish.
> > > > ________________________________
> > > > From: "effgroups@..." <effgroups@...>
> > > > Sent: Wednesday, September 7, 2011 9:40 AM
> > > > Thanks Tod for the quick answer.
> > > > The problem is that I want to run the code in the job closing
> > program.
> > > > There is only one adapter there that is when you close the job but
> I
> > > added
> > > > a few field that I want the user to fill in even they don't close
> > the
> > > job.
> > > > Maybe my only option is to run it after field change?
> > > > Ephraim
> > > > Ephraim Feldman
> > > > Date: Wed, 7 Sep 2011 05:12:53
> > > > Ephraim,
> > > > You could accomplish by using this code. This will run the code
> > after the
> > > > Update method of the Job Adapter has been called. If you want
> before
> > it
> > > > saves use BeforeAdapterMethod.
> > > > Private Sub oTrans_jobAdapter_AfterAdapterMethod(ByVal sender As
> > Object,
> > > > ByVal args As AfterAdapterMethodArgs)
> > > > ' ** Argument Properties and Uses **
> > > > ' ** args.MethodName **
> > > > ' ** Add Event Handler Code **
> > > > ' ** Use MessageBox to find adapter method name
> > > > ' EpiMessageBox.Show(args.MethodName)
> > > > Select Case args.MethodName
> > > > Case "Update"
> > > > End Select
> > > > End Sub
> > > > Hope that helps
> > > > Ted
> > > > From: Ephraim Feldman <effgroups@...>
> > > > Sent: Wednesday, September 7, 2011 12:19 AM
> > > > Subject: [Vantage] Running some VB code when saving a record
> > > > Hi all
> > > > I created a customization that connect to the JobEntry adapter and
> > > updates
> > > > some custom fields and i want it to run when the user saves the
> > record
> > > how
> > > > can i accomplish that?
> > > > here is my code:
> > > > Private Sub JobInfo(ByVal Mode As String)
> > > > 'Declare and Initialize EpiDataView Variables
> > > > Dim edvClose As EpiDataView =
> > > > CType(oTrans.EpiDataViews("Close"),EpiDataView)
> > > > 'Check if valid EpiDataView Row(s) are selected
> > > > If (edvClose.Row < 0) Then
> > > > Exit Sub
> > > > End If
> > > > 'Create instance of Adapter
> > > > Dim adapterJobEntry As JobEntryAdapter = New
> > > > JobEntryAdapter(oTrans)
> > > > adapterJobEntry.BOConnect()
> > > > 'Declare and Initialize Variables
> > > > Dim jobNum As String =
> > > > CType(edvClose.dataView(edvClose.Row)("JobNum"),String)
> > > > 'Call Adapter method
> > > > Dim result As Boolean = adapterJobEntry.GetByID(jobNum)
> > > > Try
> > > > Dim MyTXTStage as epiTextBox
> > > > MyTXTStage =
> CType(csm.GetNativeControlReference("7b45bf03-0f29-4324-bbaa-834bab503d2
> > a"),EpiTextBox)
> > > > Dim MyCHKPick as epiCheckBox
> > > > MyCHKPick =
> CType(csm.GetNativeControlReference("36009aeb-c55e-4129-b0a2-129e3faf10e
> > e"),EpiCheckBox)
> > > > Dim MyDatePick as epiDateTimeEditor
> > > > MyDatePick =
> CType(csm.GetNativeControlReference("ee001405-b7fd-41aa-a25c-536f01910fa
> > 1"),EpiDateTimeEditor)
> > > > Dim MyCHKWip as epiCheckBox
> > > > MyCHKWip =
> CType(csm.GetNativeControlReference("4193e051-a401-4076-a3e9-13678eb9d55
> > 7"),EpiCheckBox)
> > > > Dim MyDateWip as epiDateTimeEditor
> > > > MyDateWip =
> CType(csm.GetNativeControlReference("b3b29a66-ec2c-43c7-bcac-cd408dfc005
> > a"),EpiDateTimeEditor)
> > > > If Mode = "Update" Then
> > > > adapterJobEntry.JobEntryData.Tables("JobHead").Rows(0).BeginEdit()
> > > > adapterJobEntry.JobEntryData.JobHead(0)("Character01" ) =
> > > > MyTXTStage.Text
> > > > adapterJobEntry.JobEntryData.JobHead(0)("CheckBox01" ) =
> > > > MyCHKPick.Checked
> > > > adapterJobEntry.JobEntryData.JobHead(0)("Date01" ) =
> > > > MyDatePick.Value
> > > > adapterJobEntry.JobEntryData.JobHead(0)("CheckBox02" ) =
> > > > MyCHKWip.Checked
> > > > adapterJobEntry.JobEntryData.JobHead(0)("Date02" ) =
> > > > MyDateWip.Value
> > > > adapterJobEntry.JobEntryData.Tables("JobHead").Rows(0).EndEdit()
> > > > adapterJobEntry.Update()
> > > > Else If Mode = "Get" Then
> > > > MyTXTStage.Text =
> > > > MyCHKPick.Checked =
> > > > MyDatePick.Value =
> > > > MyCHKWip.Checked =
> > > > MyDateWip.Value =
> > > > End If
> > > > Catch e As Exception
> > > > End Try
> > > > 'Cleanup Adapter Reference
> > > > adapterJobEntry.Dispose()
> > > > adapterJobEntry = Nothing
> > > > End Sub
> > > > [Non-text portions of this message have been removed]
> > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > must
> > > have
> > > > already linked your email address to a yahoo id to enable access.
> > > > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder and
> > > > Crystal Reports and other 'goodies', please goto:
> > > > http://groups.yahoo.com/group/vantage/files/.
> > > > (2) To search through old msg's goto:
> > > > http://groups.yahoo.com/group/vantage/messages
> > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > must
> > > have
> > Builder and
> > must
> > > have
> > Builder and
> > > *Waffqle Driggers*
> > > *High End Dev, System Design, Profit Drinking
> > > *:: 904.962.2887*
> > > *:: waffqle@...*
> > > *:: NO FAXES*
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> have already linked your email address to a yahoo id to enable access. )
