Running Vantage 5.1 from remote site
"BTW, I've never seen any improvement in that schema cache technique. I've tried it with every release since 3.0."
I've never seen any improvement either, but thought that in your situation "maybe" it would do something. Oh well.
Troy Funte
Liberty Electronics
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Tuesday, September 03, 2002 7:51 PM
Subject: RE: [Vantage] Running Vantage 5.1 from remote site
Hey Troy,
yes, I have it installed on my PC at home. All the library files
(Progress & Vantage) reside on my PC. I just point the database to the
vantage
server. I had a direct DSL connection from work to my house (about 15 miles
away),
and I could achieve around 3 second response times. Now that I have Verizon
as my
ISP, I am not seeing those speeds.
We have done a little terminal server research, and that is the way
we are
headed. We have quite a few DSL users (sadistic $%&#'s) who want to work
from home.
As always, thanks for your response.
tried it
thanks,
Yahoo! Groups Sponsor
ADVERTISEMENT
I tried running Vantage through a DSL connection through a VPN this past
weekend and it was painfully slow. (1 minute to log into vantage,
45 seconds to query a part in part tracker).
Does anyone have any words of wisdom as to what kind of setup would be
required for acceptable performance?
thanks,
Try http://www.tridiavnc.com <http://www.tridiavnc.com/> . We like it
better than pcAnywhere, and it�s free! It would work really well over a DSL
connection.
Mike Gilchrist
Perry Technology Corporation
Phone: (860)738-2525 Ext. 122
Fax: (860) 738-2426
Email: mikeg.ptc@... <mailto:mikeg.ptc@...>
Sent: Tuesday, September 03, 2002 8:31 AM
To: 'Vantage (vantage@yahoogroups.com)'
Subject: [Vantage] Running Vantage 5.1 from remote site
thanks,
ADVERTISEMENT
<http://rd.yahoo.com/M=212804.2303158.3720906.2225242/D=egroupweb/S=17050071
83:HM/A=810373/R=0/*http://geocities.yahoo.com/ps/info?.refer=blrecs>
83:HM/A=810373/R=1/*http://geocities.yahoo.com/ps/info?.refer=blrecs>
Mike,
I use tridiavnc to connect remotely as well. I'm curious how you
initiate your connection from the remote location?
Troy Funte
Liberty Electronics
> better than pcAnywhere, and it's free! It would work really well
> over a DSL
> connection.
> Mike Gilchrist
> Fax: (860) 738-2426
> From: PLAMAN DICK [mailto:dick.plaman@...]
> past
> thanks,
> ADVERTISEMENT
> must have
> and
> ------------------------ Yahoo! Groups Sponsor
> access. )
I use PC Anywhere. Host at the office. DSL on both ends. Just like being
there.
Bob Bruton
Entek Corp.
Sent: Tuesday, September 03, 2002 7:31 AM
thanks,
ADVERTISEMENT
Robert,
you have a host to connect to. I'm talking about logging on to the
domain,
through the internet and starting a client from the connected PC.
I have the libraries installed on the remote site, but it takes forever to
do anything.
I am thinking I need either terminal server or citrix.
TridiaVNC is excellent if this is for a single user. However, it
can't support more than one connection at a time. To do that, you
should look into running Microsoft Terminal Server (or Citrix). I
have a remote site that has up to three stations which sign on
concurrently via DSL/VPN. Works great!
John Mahala
KRB Machinery
past
be
> thanks,
Dick,
> Does anyone have any words of wisdom as to what kind of setup would >
be required for acceptable performance?
A. Try installing the Vantage client programs on the remote PC.
B. If you are only supporting one remote user, then Tridia, RAdmin,
or pcAnywhere.
C. If you have more than one remote user, use Citrix.
have fun,
john
Sent: Tuesday, September 03, 2002 5:31 AM
Troy,
To connect remotely all we do is startup the TridiaVNC Viewer from the
remote location, and fill in the dialog box with the IP address of the host
computer that you wish to take over. If the host computer is running
dynamic ip, then we use a utility supplied by http://www.dynamip.com/. This
will pickup the ip address of the host if you are running the utility at the
host.
Mike
Sent: Tuesday, September 03, 2002 8:56 AM
Subject: Re: [Vantage] Running Vantage 5.1 from remote site
Mike,
Troy Funte
Liberty Electronics
> Try http://www.tridiavnc.com < http://www.tridiavnc.com/> . We like it
> over a DSL
> connection.
> Mike Gilchrist
> Fax: (860) 738-2426
> past
> thanks,
> ADVERTISEMENT
> 83:HM/A=810373/R=0/* http://geocities.yahoo.com/ps/info?.refer=blrecs>
> 83:HM/A=810373/R=1/* http://geocities.yahoo.com/ps/info?.refer=blrecs>
> must have
> and
> < http://docs.yahoo.com/info/terms/> .
> access. )
ADVERTISEMENT
Dick,
Do you actually have Vantage installed on the remote machine? If so, can you do the "Create Schema Cache File" from System Management / Utilites? It is supposed to help to increase speed of connecting to Vantage.
Troy Funte
Liberty Electronics
Sent: Tuesday, September 03, 2002 9:56 AM
Robert,
domain,
do anything.
ADVERTISEMENT
OK. So you must not be going through a Firewall... or else you opened your firewall for the connection. Our PC's only have internal IP addresses, not internet addresses. I have to initiate the connection from the HOST PC using Outlook and an email that I send. Then, using the dynamic name hosting, it connects to the remote PC automatically. I was just seeing if someone had a more simple solution for our scenario.
Troy
Sent: Tuesday, September 03, 2002 12:00 PM
Troy,
host.
Mike
Mike,
Troy Funte
Liberty Electronics
> over a DSL
> connection.
> Mike Gilchrist
> Fax: (860) 738-2426
> past
> thanks,
> ADVERTISEMENT
> must have
> and
> access. )
ADVERTISEMENT
ADVERTISEMENT
Unfortunately the host machine is running outside of the firewall. The VNC
server does have password protection, and there is a time limit associated
with its availability.
Mike
Sent: Tuesday, September 03, 2002 7:10 PM
Troy
Troy,
host
This
the
host.
Mike
Mike,
Troy Funte
Liberty Electronics
> over a DSL
> connection.
> Mike Gilchrist
> Fax: (860) 738-2426
> past
> thanks,
> ADVERTISEMENT
> must have
> and
> access. )
ADVERTISEMENT
have
ADVERTISEMENT
ADVERTISEMENT
83:HM/A=810327/R=0/*http://geocities.yahoo.com/ps/info?.refer=blrecs>
83:HM/A=810327/R=1/*http://geocities.yahoo.com/ps/info?.refer=blrecs>
Hey Troy,
vantage
away),
as my
we are
from home.
tried it
thanks,
