Running vantage clustered between two servers
Hi,
Thanks for that. I will try it out this week.
Regards,
Ross
On 5 Mar 2012, at 12:57, "Hatcher, John" <johnh@...> wrote:
> What is your setup for storage? We have found that this plays a big
> role in the overall performance of your Epicor system.
> You may want to take a look at ProTop. This is a free tool that we
> found very helpful in analyzing our system to get a better idea of where
> the bottlenecks were.
> John A. Hatcher
> Manager of IS
> Versa Products Co., Inc.
> (201) 843-2400 x4148
> (201) 843-2931 fax
Hi,
I don't know if anyone is able to help. We are running vantage using a progress database on a single windows 2003 server. I am looking for some help on how to split the load between two servers by clustering them. I found some notes on the epicor website for the windows server setup but no notes on the application servers settings and how I should split them as well as the settings required.
Any help or documentation would be appreciated.
Regards,
Ross
A truly clustered DB requires the purchase of Fathom Replication from
Progress and it is a very involved process.
I suppose the question is what you're the end result is that you are looking
for with setting this up, there may be other alternatives besides clustering
to get what you want from the system.
Ross Robertson
Sent: Saturday, March 03, 2012 12:34 PM
To: Vantage Group
Subject: [Vantage] Running vantage clustered between two servers
Hi,
Regards,
Ross
Hi,
We are using a virtual environment and our production server has 8 cores allocated to it. We have complaints that vantage in general(screen access/printing reports/ entering data) is slow. When speaking with epicor support they advised that if we clustered two servers and split the CPU and memory between the two that this could help.
This is what I was going to try and achieve and split the application servers as well and try to test the improvement.
Regards,
Ross
> Ross Robertson
> To: Vantage Group
> Hi,
> Regards,
> Ross
Before you go trough all that trouble watch your load during peak use, I am
willing to bet that CPU and RAM sit there looking bored. 90% of the issues
with Vantage do not arise from High CPU usage or even Ram ove-rutilizatoin
the problem is generally the IO bottle neck. I bet its your hard-drives
that can't keep up. If that's the case you can do a whole lot more by
fixing your raid config / adding more spindles than by clustering things.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Sun, Mar 4, 2012 at 6:31 AM, Ross Robertson <ross_edinburgh@...>wrote:
> Hi,
> Regards,
> Ross
> looking
> clustering
> Behalf Of
> > Ross Robertson
> > To: Vantage Group
> > Hi,
> no
> > Regards,
> > Ross
> have
This is correct, especially since the I/O bottleneck on the DB will still
exist no matter how many application servers you have running, and it could
possibly get worse since you are eliminating shared memory usage by
separating out servers.
You're system configuration, both hardware and settings could play a huge
part in any issues you are having, and I suspect one of those is really the
culprit. How many users are you running I have never really seen an
installation with fewer than 250 or so office users actually require a
clustering of application servers.
Jose Gomez
Sent: Sunday, March 04, 2012 9:28 AM
Subject: Re: [Vantage] Running vantage clustered between two servers
the problem is generally the IO bottle neck. I bet its your hard-drives that
can't keep up. If that's the case you can do a whole lot more by fixing your
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Hi,
> Regards,
> Ross
> > from Progress and it is a very involved process.
> looking
> clustering
> Behalf Of
> > Ross Robertson
> > To: Vantage Group
> > Hi,
> no
> > Regards,
> > Ross
> > must
> have
> > Builder and Crystal Reports and other 'goodies', please goto:
John A. Hatcher
Manager of IS
(201) 843-2931 fax
