I chalked this one up to [windows] user profile corruption, recreated my profile and all is well now.
Thanks for you help in troubleshooting it.
Plamen
Plamen
--- In vantage@yahoogroups.com, "plamen21" <plamen21@...> wrote:
> Getting warmer now. While it didn't fix it, it gave me the idea to try a different Windows user - and that worked ok.
> So there must be a bad file/folder within my user profile. [it is not the .rpt noted in the error but possibly one that is used to recreate it].
> Are there any files/folders stored in / linked to the individual Windows user profiles?
> Plamen
> --- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@> wrote:
> > You can try to delete the local application data folder on the client. That
> > has fixed strange behaviors at times.
> > Each OS has them in slightly different places. On my PC it is:
> > C:\Documents and Settings\All Users\Application Data\Epicor\Vantage
> > Exit Vantage. Delete all of the version folders that are under the above
> > path. Restart Vantage.
> > See if that makes a difference.
> > Ross
> > -----Original Message-----
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> > plamen21
> > Sent: Thursday, April 08, 2010 1:49 PM
> > Subject: [Vantage] Re: Sales Gross Margin Report Error
> > Ok this is weird. It is somehow related to the local machine (even under
> > different users) and only for this report (other reports run fine). I
> > repair/reinstalled the client completely starting from .net and still it
> > does the same thing.
> > Any ideas?
> > Plamen
> > Systems Administrator
> > Art Display Co.
> > --- In vantage@yahoogroups.com, "plamen21" <plamen21@> wrote:
> > > Thanks you so much.
> > > I tried to run it with your report and ... got the exact same error
> > message. Then I figured to ask someone else to run it from their computer
> > and it ran fine - both for yours and mine. I recently started posting the
> > Vantage version at the beginning of my first message to avoid ambiguity - a
> > lot of people here use different versions.
> > > My next guess is the crystal viewer/runtime on my machine needs to be
> > reinstalled. (I did recently try to install a second instance of vantage -
> > for the test server - without reinstalling .net, crystal runtime, and web) .
> > It is still a mystery why it doesn't show on other reports. I will post what
> > I discover.
> > > Plamen Cheshmedjiev
> > > Art Display Co.
> > > > Plamen,
> > > > I don't see a font color formula in the original SGMargin.rpt report.
> > > > The formula looks incomplete. Has the report ever been edited? There
> > is no
> > > > integer to compare to, only an operator.
> > > > I don't know what version you are on but I have sent you the original
> > > > version from 8.03.407 to your email.
> > > > Ross
> > Of
> > > > plamen21
> > > > Sent: Thursday, April 08, 2010 8:50 AM
> > > > Thanks Ross.
> > > > Since I haven't touched the report nor the RDD, nor the xml. I just
> > > > double-checked the Report style - it is using the original SGMargin.rpt
> > and
> > > > the system RDD SGMargin.
> > > > This is really weird since it worked fine about a month ago and neither
> > file
> > > > has changed.
> > > > I am not sure what to make of it.
> > > > I found and tried to open the report, as you suggested, tried print
> > preview,
> > > > and I got a very similar error "A number,...or string expected" (See
> > > > Photos/Vantage Errors/Number Expected), then it opens Formula Workshop
> > with
> > > > the formula in question (See Photos/Vantage Errors/FormulaWorkshop).
> > > > if CurrentFieldValue < - then 255 else
> > > > DefaultAttribute;
> > > > I should mention that I get the same error/behaviour on my test server
> > (on a
> > > > separate machine).
> > > > Help!
> > > > Plamen
> > > > > Have you changed the Report Data definition? It looks like an error
> > that
> > > > > occurs when a field is in the crystal report but the field is missing
> > from
> > > > > the XML dataset.
> > > > > Usually opening up the Crystal report and attaching it to the XML file
> > for
> > > > > preview will isolate the culprit.
> > > > > Ross
> > Behalf
> > > > Of
> > > > > plamen21
> > > > > Sent: Wednesday, April 07, 2010 4:03 PM
> > > > > Subject: [Vantage] Sales Gross Margin Report Error
> > > > > Vantage 407.803c
> > > > > When I run Sales Gross Margin Report I started getting an error:
> > > > > A number, currency amount, boolean, date-time, or string is expected
> > here.
> > > > > Details: errorKind
> > > > > Error in File c:\DOCUME~1\User\Locals~1\temp\SGMargin {568..}.rpt
> > > > > Error in formula <Font_Color>.
> > > > > 'if CurrentFieldValue < - then 255 else
> > > > > DefeultAttribute;'
> > here.
> > > > > Details: errorKind
> > > > > Plamen Cheshmedjiev
> > > > > Art Display Co.
> > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > > > have
> > > > > already linked your email address to a yahoo id to enable access. )
> > > > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and
> > > > > Crystal Reports and other 'goodies', please goto:
> > > > > http://groups.yahoo.com/group/vantage/files/.
> > > > > (2) To search through old msg's goto:
> > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > have
> > and
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
