Sales Kit Components Print Twice on Invoice
I assume you use Crystal Report for your documents. and I also assume you generate your documents from xml files. if both are correct, review the detail part of your xml and see if the lines are listed twice there. if not then it is a problem within your Crystal report.
BILL R. KING
J&B Industrial Services
(806).776.4409 Office
(254).592.4397 Cell
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Kerry Travis
Sent: Tuesday, March 09, 2010 9:30 AM
Subject: Re: [Vantage] Sales Kit Components Print Twice on Invoice
Dale,
Yes, the Invoice Print is set to standard, so that can't be the issue.
Thanks for replying.
Kerry
From: Dale Schuerman <dale.schuerman@...<mailto:dale.schuerman%40ramsys.com>>
Sent: Tue, March 9, 2010 10:23:44 AM
Subject: RE: [Vantage] Sales Kit Components Print Twice on Invoice
Kerry,
First thing to check is has your company modified the invoice print.
If you modified the print then run the standard version to see if the
problem goes away.
This will narrow it down to continue researching.
Hope this helps.
Dale E. Schuerman
Senior Consultant
Epicor Certified Consulting Partner
RAM Software Systems, Inc.
972-669-0763 x233 (voice)
972-669-9603 (fax)
mailto:dale.schuerman@ ramsys.com
<BLOCKED::blocked: :mailto:dale.schuerman@ ramsys.com> (email)
http://www.ramsys com <BLOCKED::blocked: :http://www.ramsys com/>
(website)
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Kerry Travis
Sent: Tuesday, March 09, 2010 9:16 AM
To: vantage@yahoogroups .com
Subject: [Vantage] Sales Kit Components Print Twice on Invoice
We are on Vantage 8.03.408B.
We set up our kits to allow component and parameter changes on the fly.
Because of the nature of our business, each kit is pretty much unique.
We have one main component which appears in each kit. We either copy
and paste new components from Excel at the Order Entry stage, or we do a
part search and add the components.
The packing slip prints out fine. You see the Line Item, and in the box
below, the components print out.
However, when we invoice, you see the Line Item, and the kit components
print out in the box below, the same as the Packing Slip. Then, below
that, each item we added on the fly shows up as a separate line item. In
effect, these components are printing out twice.
Does anyone know what causes this?
Thanks a lot for your help.
Regards,
Kerry Travis
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys com
The information contained in this message is intended solely for the individual to whom it is specifically and originally addressed. This message and its contents may contain confidential or privileged information. If you are not the intended recipient, you are hereby notified that any disclosure or distribution, or taking any action in reliance on the contents of this information, is strictly prohibited.
We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
This message (including any attachments) is intended only for
the use of the individual or entity to which it is addressed and
may contain information that is non-public, proprietary,
privileged, confidential, and exempt from disclosure under
applicable law or may constitute as attorney work product.
that any use, dissemination, distribution, or copying of this
communication is strictly prohibited. If you have received this
communication in error, notify us immediately by telephone and
(i) destroy this message if a facsimile or (ii) delete this message
immediately if this is an electronic communication.
Thank you.
We went live June 1 and are using sales kits. We have found numerous
problems and issues with the use of sales kits. The worst of the
problems came from the combination of sales kits and order releases.
We could never get multiple releases with kits to work correctly –
too many bugs to count.
My users are wondering if others are using sales kits and how they
structure them. We are an extremely lean manufacturing facility. The
reason we went to them was that we have very small assemblies – place
a sticker on a motor, 5 minutes of labor part assemblies and things
like that. The mfg floor did not want to use jobs for those
instances. We are considering a move to Kanban receipts as a means of
alleviating a number of sales kit issues and getting around the job
creation problem (since that Kanban receipts process creates, back
flushes and closes the job for you.)
The problem with Kanban receipts is that there is no signal to
process the Kanban Receipt when using a sales order pick list.
We ran into the following problems (an abbreviated list):
- Sales Kit Line Numbers - sales kits are assigned unique order line
numbers – each order line explodes into multiple lines – we had to
customize a bunch of forms/reports to show the "display" order line
sequence rather than the order line sequence. It was confusing for
customers to see line #1, #6 and #10 and that was their 3 line order.
- Sales kit RMA processing – you can't return the parent item – you
have to return all the components. This causes problems because
pricing is at parent level – components price doesn't add up to
parent price.
- Shipping documents – order line # issues again and components show
on export documents
- Sales reports get doubled up because of the extra kit lines
- Shipments post with an unknown account if you don't unpack all the
components of a kit, then the parent. In effect you have to unpack
the entire pack if you have to drop anything that might be a kit
component.
My users would like to know how other companies are using kits.
Specifically, what other alternatives have you used to work around
the issues we've hit? Have you run into other issues with Sales kits?
Hi Dave,
You don't mention which version you are running. We are currently on
803.305L and planning to upgrade to 405 (or later) - partly in response
to these sales kit (and configurator) issues which we have been informed
will be resolved sufficiently to meet our needs.
Are you aware of the sales kits parameters? These are found on the part
maintenance screen under plants/saleskits. One of these is 'Print
components on pack slip'. You might want to switch that one off?
line
numbers - each order line explodes into multiple lines - we had to
We too changed the customer facing docs to remove the line nos to avoid
confusion.
- Shipping documents - order line # issues again and components show
on export documents - I created bespoke BAQ reports for internal and
delivery picklists - partly to deal with our large un- assembled parts
(see below).
Here's what we did. We are currently only using kits for a few smaller
parts. We were unable to use it for large unassembled parts for 2
reasons:
The components are configured items which we either buy in from a sister
company or manufacture ourselves to order. We havn't yet added our own
manufactured parts to the system. For the purchased components we had to
resort to creating a job with one operation 'Collate' with the
components listed as purchased job mtls - however as you realize, this
is creating, what we see as unnecessary, extra work for us.
1. They can be shipped by components and assembled onsite (eg first
shipment is all component A but none of component B because they won't
need or have room for it until the following week). Sales kits will not
currently allow this.
2. We cannot do configured parts with BOMs as children of configured
parts with BOMs. This is what I understand will be available in 400+
upgrades.
kind regards
Debbie Stokes
This email is intended for the addressee only and may contain information that is privileged and confidential. If you are not the intended recipient, you must not copy, distribute or take any
action in reliance on it. If this email has been sent to you in error, please notify us immediately by telephone.
This has been transmitted by -
Hilo-PSS Group
Murdock Road
Dorcan Industrial Estate
Swindon
SN3 5HY
Company Registration No: 01028915.
The views within this email are those of the author and not
necessarily those of Planned Storage Systems Ltd.
** This email has been scanned for viruses, vandals and malicious content **
We set up our kits to allow component and parameter changes on the fly. Because of the nature of our business, each kit is pretty much unique. We have one main component which appears in each kit. We either copy and paste new components from Excel at the Order Entry stage, or we do a part search and add the components.Â
The packing slip prints out fine. You see the Line Item, and in the box below, the components print out.
However, when we invoice, you see the Line Item, and the kit components print out in the box below, the same as the Packing Slip. Then, below that, each item we added on the fly shows up as a separate line item. In effect, these components are printing out twice.Â
Does anyone know what causes this?Â
Regards,
Kerry Travis
Kerry,
problem goes away.
Hope this helps.
Dale E. Schuerman
Senior Consultant
972-669-9603 (fax)
mailto:dale.schuerman@...
<BLOCKED::blocked::mailto:dale.schuerman@...> (email)
http://www.ramsys.com <BLOCKED::blocked::http://www.ramsys.com/>
(website)
Of Kerry Travis
Regards,
Kerry Travis
Attention:
by MailMarshal SMTP
For more information go to http://www.ramsys.com
Dale,
Kerry
Â
Kerry,
problem goes away.
Hope this helps.
Dale E. Schuerman
Senior Consultant
972-669-9603 (fax)
(website)
Of Kerry Travis
Regards,
Kerry Travis
Attention:
by MailMarshal SMTP
Normally when I see extra information on a crystal report it is caused by a sub-table in the linkage has two or more records.
For example if you use a number in the orderdtl (Order line item) table in a math equation, if will be off by the number of
Orderrel (Order releases).
I just looked quickly at the links in the crystal report (407c version) and the Invoice detail file links to four field service tables.
If you do not have field service, I am not sure what the problem is.
The next step would be look for the duplicate kits in the xml file and try to determine the reason.
Dale E. Schuerman
Senior Consultant
972-669-9603 (fax)
mailto:dale.schuerman@... <BLOCKED::blocked::mailto:dale.schuerman@...> (email)
http://www.ramsys.com <BLOCKED::blocked::http://www.ramsys.com/> (website)
Dale,
Kerry
From: Dale Schuerman <dale.schuerman@... <mailto:dale.schuerman%40ramsys.com> >
Kerry,
problem goes away.
Hope this helps.
Dale E. Schuerman
Senior Consultant
972-669-9603 (fax)
(website)
Of Kerry Travis
Regards,
Kerry Travis
Attention:
by MailMarshal SMTP
