Thank you Dale, that's exactly what I needed! I had actually
forgotten that that is how to modify the reports. Having to learn
Crystal, BAQs, Dashboards, and Customization all at the same time
everything sometimes wantes to run together in my head!
--- In vantage@yahoogroups.com, "Dale Schuerman" <dale.schuerman@...>
wrote:
>Behalf
> Sean,
> You modify the Epicor reports by using the
> System Management --> Company Maintenance --> Report Data Definition
> OrderAck is the one for SO Acknowledgement. You can not modify the
> Epicor version so you have to make a copy and modify it.
> After you modify it then you go to
> System Management --> Company Maintenance --> Report Style
> Add a new SO Style using your new Data definition.
> Hope this helps
> Dale Schuerman
> Senior Consultant
> RAM Software Systems, Inc.
> 1701 North Collins Suite 200
> Richardson, Texas 75080
> Phone: (972) 669-0763
> Fax: (972) 669-9603
> Web Site: www.ramsys.com <blocked::http://www.ramsys.com/>
> Of Sean TolerSales
> Sent: Thursday, August 07, 2008 7:46 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Sales Order Acknowledgement Crystal Report
> Does anyone know which BAQ is used by the system to create the
> Order Acknowledgement? I want to add some more databases to theversion
> Crystal Report but will need to do so in the BAQ. I am running
> 8.03.
