Thank you for your reply Aaron.
When you mentioned write the value directly; do you
mean to actually click on the release tab and type it
in? or write code? I wrote some code so it gets
triggered when a new release line is entered; the
trigger is using the Epiview notification Add event;
however it only gets triggered when you actually click
on "File", "New Release" or select it from the white
sheet icon; it does not get triggered for the first
release record which gets inserted automatically right
after a new detail line is entered.
I used ShortChar01 as an example, but I am also trying
to carry over a checkbox01 field as well. ShortChar01
has purely text in it, some comments.
Thanks again,
Percy
--- Aaron Continelli <aaron@...> wrote:
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Thanks again,
Percy
> You will need to write the ShortChar02 value____________________________________________________________________________________
> directly to the Order Release.
> What type of data are you storing in ShortChar02 at
> the line level that
> needs to be at the Release level?
> Aaron Continelli
> www.cre8tivetechs.com
> Office - (858) 457-2786
> Fax - (858) 457-2787
> Cell - (858) 967-4352
> E-mail - aaron@...
> Cre8tiveLogo Creative business intelligence for
> your enterprise.
> EPICOR_Authorized
> Cre8tive Technology & Design 4455 Morena Blvd. Suite
> 115, San Diego CA
> 92117
> From: vantage@yahoogroups.com
> [mailto:vantage@yahoogroups.com] On Behalf Of
> therealhackercat
> Sent: Tuesday, March 25, 2008 9:08 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Sales Order Entry Information
> automatically carried from
> Line to Release
> Hello Everyone,
> I am presented with a new challenge and I'm hoping I
> can get some
> assistance on this. I customized Sales Order Entry.
> I create a new
> order, after saving it, I enter a new line, enter
> all relevant
> information and save again. The Sales order entry
> program
> automatically creates a new release line, carrying
> over the dates I
> specified at the line level. That's all great;
> However, I customized the Line detail Grid at the
> bottom of the
> Summary tab and included to display the ShortChar02
> field; yet, after
> I finish entering the line and save, all values get
> carried to
> release level except for the userdefined field,
> ShortChar02.
> Has anyone found a method to carry userdefined
> fields from OrderDtl
> to OrderRel?
> I looked at the Custom FIeld Map utility found in
> "Utilities";
> unfortunately, there is predefined list of tables
> that can be used as
> source and target.
> I also enabled tracing and exported the XML file to
> see what methods
> are called, but it looks like all of the works is
> against the
> OrderDtl table and none to OrderRel.
> Any help would be greatly appreciated,
> Percy Perez
> [Non-text portions of this message have been
> removed]
