can someone offer some advice about using the salvage feature on job
material? (or even tell me if i should be trying to use it). we have a
battery pack we built for a customer and for whatever reason we have
accepted the packs back as a return. the packs are now worthless, but the
battery cells in the packs are expensive and can used in other assemblies.
i have 90 completed packs in stock as a result of the credit i cut the
customer. i'd like to set up a job to consume the 90 packs and return 180
cells to stock. do i set up the cell part number as the top assembly part
(the cell is normally a "stocked, purchased" part) on the job with .5 of the
pack per unit as material on the job? or is the assembled pack considered
material for the job and then i use the "salvage" feature for that material
line? if the "salvage" feature is the thing to use, what should we use as
the top assembly number (i tried just using a made up part number on the
job, but the system yakked at the warehouse stocking location input)?
any comments and advice would be appreciated,
james martin
james martin
