SC Newbie trying to create my first workflow
Here is a link to a cheat sheet I use to get everything but the workflow hooked up correctly. As long as I follow this, my only issues seems to be workflow related.
Regards,
Jim Pratt
http://f1.grp.yahoofs.com/v1/MCToSjXytauRrKvVWr6Aad0zwSbakbErO5NXXxAoM_xOlHmxXQWBBJ9abpSk4jc5oTmfsGV7jCqpk_ytVxDoYNDwwBM/Service%20Connect%
20workflows/Service%20Connect%20Cheet%20Sheet_R2.doc
--- In vantage@yahoogroups.com, "Charlie Wilson" <foamdesigncsw@...> wrote:
> After attending the SC Class I learned that this field is used to create a
> "space" where data is passed in and out of for the service connect. If this
> field is not filled in it generates a location randomly. There is a
> possibility that the same space could in theory be used twice by the same
> flow which in turn could cause issues. However after learning this I have
> never seen this happen and I have been leaving the field blank ever since I
> started using SC.
> Just an FYI!
> ~Charlie
> _____
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Aaron
> Sent: Tuesday, October 27, 2009 4:21 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: SC Newbie trying to create my first workflow
> You would be correct sir! Doh!
> Sometimes it's the little things that hurt.
> Aaron
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Matt
> Caldwell" <matt@> wrote:
> > It doesn't sound like you have the Message Map setup.
> > From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> [mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
> Behalf
> > Of Aaron
> > Sent: Tuesday, October 27, 2009 1:17 PM
> > To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > I'm running into this same issue with my first Service Connect. Without
> > posting a lot of XML, I'm getting "Unable to resolve map for incoming
> > message".
> > The grey-book 'course' is my only reference material. I'm lost in the
> > woods without any breadcrumbs.
> > Ideas? Help?
> > TIA,
> <mailto:vantage%40yahoogroups.com> ,
> > "Charlie Wilson" <foamdesigncsw@> wrote:
> > > I leave it blank most of the time.
> > > ~Charlie
> > > _____
> <mailto:vantage%40yahoogroups.com> ] On
> > Behalf Of
> > > Mark Tellefson
> > > Sent: Friday, March 06, 2009 2:03 PM
> > > Subject: RE: [Vantage] SC Newbie trying to create my first workflow
> > > In the example they had the following for the ConversionCfg field in
> > the
> > > Input Channel:
> > > <DefaultNamespace>http://epicor. <http://epicor. <http://epicor.com/bom>
> com/bom>
> > > com/bom</DefaultNamespace>
> > > I had changed it from bom to part since I am only dealing with the
> > part
> > > table. There was no explanation of what this field does of if I should
> > > be replacing <DefaultNamespace> with something. Any ideas?
> > > ________________________________
> > On
> > > Behalf
> > > Of Charlie Wilson
> > > Sent: Friday, March 06, 2009 12:11 PM
> > > It looks like your message mapping or inbound channel is messed up.
> > > ~Charlie
> > > _____
> > > Behalf Of
> > > rapat_mark
> > > Sent: Friday, March 06, 2009 1:01 PM
> > > Subject: [Vantage] SC Newbie trying to create my first workflow
> > > I am trying to create my first workflow by altering the workshop
> > example
> > > from the self-paced tutorial. I want to import parts from an Excel
> > > file. Right now it is only trying to bring in the part number and
> > > description. It processes the file but I don't receive the email and
> > > the parts do not show up in the Part Master. The text from the inbound
> > > messages is below.
> > > 1st Execution Point:
> > > <msg:msg
> > > xmlns:msg="http://Epicor. <http://Epicor.
> > > <http://Epicor. <http://Epicor.com/InternalMessage/1.1>
> com/InternalMessage/1.1> com/InternalMessage/1.1
> > > <http://Epicor. <http://Epicor. <http://Epicor.com/InternalMessage/1.1>
> > > com/InternalMessage/1.1> >
> > > com/InternalMessage/1.1"><msg:req><msg:dta><tab\
> > > le
> > > xmlns="http://epicor. <http://epicor. <http://epicor.
> <http://epicor.com/part> com/part>
> > com/part
> > > <http://epicor. <http://epicor. <http://epicor.com/part> com/part>
> com/part> >
> > > com/part"><row><Part_x0020_Number>SCTEST01</Part_x0\
> > > 020_Number><Description>Test Part
> > 1</Description></row><row><Part_x0020_Number>SCTEST02</Part_x0020_Number
> > 2</Description></row><row><Part_x0020_Number>SCTEST03</Part_x0020_Number
> > 3</Description></row><row><Part_x0020_Number>SCTEST04</Part_x0020_Number
> > > 4</Description></row></table></msg:dta></msg:req></msg:msg>
> > > 2nd Execution Point:
> > > <?xml version="1.0"?>
> > > <msg:msg xmlns:xsi="http://www.w3.
> > > <http://www.w3. <http://www.w3.
> <http://www.w3.org/2001/XMLSchema-instance> org/2001/XMLSchema-instance>
> > > org/2001/XMLSchema-instance> >
> > > org/2001/XMLSchema-instance"
> > > xsi:schemaLocation="http://Epicor.
> > > http://SCSHost/ <http://SCSHost/
> > > <http://SCSHost/ <http://SCSHost/schemas/epicor/ScaInternalMsg.xsd>
> > > schemas/epicor/ScaInternalMsg.xsd> >
> > > schemas/epicor/ScaInternalMsg.xsd">
> > > <msg:req tag="[ScaMessenger: Operate method error]">
> > > <msg:ers><msg:error
> > > type="COM"><msg:number>0x80004005</msg:number><msg:description>Operate
> > > after checking data failed</msg:description><msg:source>
> > > Method: CListening::Operate
> > > SrcFile: Listening.cpp
> > > SrcLine: 275</msg:source></msg:error><msg:error
> > > type="COM"><msg:number>0x80004005</msg:number><msg:description>Unable
> > to
> > > resolve map for incoming message.</msg:description><msg:source>
> > > Method: CConverter::ResolveMap
> > > SrcFile: Converter.cpp
> > > SrcLine: 434</msg:source></msg:error><msg:error
> > > type="COM"><msg:number>0x80004005</msg:number><msg:description>No
> > > matching mapping was found</msg:description><msg:source>
> > > SrcLine: 394</msg:source></msg:error></msg:ers> <msg:dta>
> > > <![CDATA[<msg:msg
> > > le
> > com/part
> com/part> >
> > > </msg:dta>
> > > </msg:req>
> > > </msg:msg>
> > > Any help as to where to look for my problem would be greatly
> > > appreciated.
> > > Mark
> > > No virus found in this incoming message.
> > > Checked by AVG - www.avg.com
> > > Version: 8.0.237 / Virus Database: 270.11.4/1976 - Release Date:
> > > 02/27/09
> > > 13:27:00
> > 02/27/09
> > > 13:27:00
I am trying to create my first workflow by altering the workshop example
messages is below.
<msg:msg
xmlns:msg="http://Epicor.com/InternalMessage/1.1"><msg:req><msg:dta><tab\
le
xmlns="http://epicor.com/part"><row><Part_x0020_Number>SCTEST01</Part_x0\
1</Description></row><row><Part_x0020_Number>SCTEST02</Part_x0020_Number\
2</Description></row><row><Part_x0020_Number>SCTEST03</Part_x0020_Number\
3</Description></row><row><Part_x0020_Number>SCTEST04</Part_x0020_Number\
<msg:msg xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://Epicor.com/InternalMessage/1.1
http://SCSHost/schemas/epicor/ScaInternalMsg.xsd">
<msg:ers><msg:error
type="COM"><msg:number>0x80004005</msg:number><msg:description>Unable to
<![CDATA[<msg:msg
le
</msg:dta>
</msg:req>
</msg:msg>
appreciated.
Mark
~Charlie
_____
rapat_mark
messages is below.
<msg:msg
xmlns:msg="http://Epicor. <http://Epicor.com/InternalMessage/1.1>
le
xmlns="http://epicor. <http://epicor.com/part>
<http://www.w3.org/2001/XMLSchema-instance> org/2001/XMLSchema-instance"
xsi:schemaLocation="http://Epicor. <http://Epicor.com/InternalMessage/1.1>
<msg:ers><msg:error
<![CDATA[<msg:msg
le
</msg:dta>
</msg:req>
</msg:msg>
appreciated.
Mark
Version: 8.0.237 / Virus Database: 270.11.4/1976 - Release Date: 02/27/09
13:27:00
In the example they had the following for the ConversionCfg field in the
Input Channel:
<DefaultNamespace>http://epicor.com/bom</DefaultNamespace>
I had changed it from bom to part since I am only dealing with the part
Of Charlie Wilson
~Charlie
_____
Behalf Of
rapat_mark
messages is below.
<msg:msg
<http://Epicor.com/InternalMessage/1.1> >
le
xmlns="http://epicor. <http://epicor.com/part <http://epicor.com/part> >
<http://www.w3.org/2001/XMLSchema-instance> >
<http://SCSHost/schemas/epicor/ScaInternalMsg.xsd> >
<msg:ers><msg:error
<![CDATA[<msg:msg
le
</msg:dta>
</msg:req>
</msg:msg>
appreciated.
Mark
02/27/09
13:27:00
~Charlie
_____
Mark Tellefson
Input Channel:
<DefaultNamespace>http://epicor. <http://epicor.com/bom>
Behalf
Of Charlie Wilson
~Charlie
_____
Behalf Of
rapat_mark
messages is below.
<msg:msg
<http://Epicor.com/InternalMessage/1.1> com/InternalMessage/1.1
le
xmlns="http://epicor. <http://epicor. <http://epicor.com/part> com/part
<http://epicor. <http://epicor.com/part> com/part> >
<http://www.w3. <http://www.w3.org/2001/XMLSchema-instance>
<msg:ers><msg:error
<![CDATA[<msg:msg
le
</msg:dta>
</msg:req>
</msg:msg>
appreciated.
Mark
02/27/09
13:27:00
13:27:00
I'm running into this same issue with my first Service Connect. Without posting a lot of XML, I'm getting "Unable to resolve map for incoming message".
The grey-book 'course' is my only reference material. I'm lost in the woods without any breadcrumbs.
Ideas? Help?
TIA,
> ~Charlie
> _____
> Mark Tellefson
> Input Channel:
> Behalf
> Of Charlie Wilson
> ~Charlie
> _____
> Behalf Of
> rapat_mark
> messages is below.
> <msg:msg
> le
> <msg:ers><msg:error
> <![CDATA[<msg:msg
> le
> </msg:dta>
> </msg:req>
> </msg:msg>
> appreciated.
> Mark
> 02/27/09
> 13:27:00
> 13:27:00
Of Aaron
message".
Ideas? Help?
TIA,
> ~Charlie
> _____
Behalf Of
> Mark Tellefson
the
> Input Channel:
part
On
> Behalf
> Of Charlie Wilson
> ~Charlie
> _____
> Behalf Of
> rapat_mark
example
> messages is below.
> <msg:msg
> le
com/part
> <msg:ers><msg:error
to
> <![CDATA[<msg:msg
> le
com/part
> </msg:dta>
> </msg:req>
> </msg:msg>
> appreciated.
> Mark
> 02/27/09
> 13:27:00
02/27/09
> 13:27:00
Aaron
> Of Aaron
> message".
> Ideas? Help?
> TIA,
> > ~Charlie
> > _____
> Behalf Of
> > Mark Tellefson
> the
> > Input Channel:
> part
> On
> > Behalf
> > Of Charlie Wilson
> > ~Charlie
> > _____
> > Behalf Of
> > rapat_mark
> example
> > messages is below.
> > <msg:msg
> > le
> com/part
> > <msg:ers><msg:error
> to
> > <![CDATA[<msg:msg
> > le
> com/part
> > </msg:dta>
> > </msg:req>
> > </msg:msg>
> > appreciated.
> > Mark
> > 02/27/09
> > 13:27:00
> 02/27/09
> > 13:27:00
started using SC.
Just an FYI!
~Charlie
_____
Aaron
Aaron
Behalf
> Of Aaron
> message".
> Ideas? Help?
> TIA,
> > ~Charlie
> > _____
> Behalf Of
> > Mark Tellefson
> the
> > Input Channel:
com/bom>
> part
> On
> > Behalf
> > Of Charlie Wilson
> > ~Charlie
> > _____
> > Behalf Of
> > rapat_mark
> example
> > messages is below.
> > <msg:msg
> > le
> com/part
com/part> >
> > <msg:ers><msg:error
> to
> > <![CDATA[<msg:msg
> > le
> com/part
com/part> >
> > </msg:dta>
> > </msg:req>
> > </msg:msg>
> > appreciated.
> > Mark
> > 02/27/09
> > 13:27:00
> 02/27/09
> > 13:27:00
