Well, at least it didn't take you too long :) Happy Friday!
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of sbraudrick@...
Sent: Friday, March 11, 2011 3:18 PM
Subject: [Vantage] Re: SC XPath Help
Aww man, right when I was getting ready to leave early! :)
Thanks a ton, that did the trick!
Sean
Sean
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Karen Schoenung <kschoenung@...> wrote:
> The easiest way I know is to use a conversion to bring your Original data back up a level - in step right before your subworkflow. Then you can probably use your
> /msg:msg/msg:req/msg:dta/dta:table/dta:row
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of sbraudrick@...
> Sent: Friday, March 11, 2011 2:34 PM
> Subject: [Vantage] SC XPath Help
> I'm developing a workflow where data will pass from the main workflow to a sub-workflow and be cycled through.
> Due to the fact that I've done some operations in the main workflow I've passed my entire incoming dataset to a process container called "Original Data" so I can get it to the sub-workflow.
> When trying to configure the XPath using the XPath builder it generates a long bit of gibberish that references Epicor.com in several places but I remember from past workflows that I had to enter the XPath by hand.
> The example I'm working off of from another working workflow is:
> I'm trying to get it get me here:
> /msg/req/wfl/usr/OriginalData/table/row such as:
> /msg:msg/msg:req/msg:wfl/wfl:usr/usr:OriginalData/OriginalData:table/OriginalData:row
> /msg:msg/msg:req/msg:wfl/wfl:usr/usr:OriginalData/usr:table/usr:row
> etc...
> I've tried every iteration that makes sense to me and am confronted each time with an Unexpected error 0x80004005 Reason: Namespace prefix is not declared.
> Can anyone help me translate my example to the desired destination?
> Thanks,
> Sean
